Question about Drills
Durabuilt cordless screwdriver battery - Drills
Durabuilt 18 v 1 hour charge battery
Go online and buy the battery, it is likely available on eBay.
Sep 03, 2016 | Drills
Question about Kawasaki cordless screwdriver. Model 200/min (Walmart, Home Depot) Battery registers as charged, but the bit will not turn. Does not appear locked.
Some cordless screwdrivers give every indication they are charged when, in fact, they are not. Either the charger or battery is defective.
May 01, 2016 | Electrical Supplies
How do I get brushes for a durabuilt model DP0000201 compressor
Durabuilt may be able to advise where to obtain new brushes.
Sep 17, 2014 | Air Tools & Compressors
What settings on a universal charger do I use for a Black & Decker 2.4 V cordless screwdriver
I would say that a output voltage of not more than 2.8 volt and the output amp should not exceed 60% of the Amp hour rating of the battery. Example if the battery is a 2000 mah battery the charging amp should not be more than 1400 milli amp or 1.4 amp
Jan 12, 2014 | Black & Decker 9072CTN Cordless...
Parts for Durabuilt Air Compressor #DP0200604
Durabuilt air compressor replacement parts can be found on amazon, here: Amazon com Durabuilt Air Compressor. Wish you best of luck. Cheers
Feb 19, 2012 | Air Tools & Compressors
My Craftsman cordless screwdriver doesn't charge
you have a short in the battery or charger,,,very dangerous ,,the batt could explode
Jul 27, 2010 | Craftsman 14.4 volt Cordless Drill/Driver...
Black & Decker Nickel Cadmimum replacement battery
Check the store where you purchased the screwdriver but you will find its cheaper to buy a new screwdriver with new batteries than to buy just the batteries.
Jul 12, 2010 | Black & Decker 9072CTN 2.4V Cordless...
Drills Logo
37 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
