Question about Ovens
Kenmore C970-645121
Oven elements have power going to them, and there is a fully powered circuit on both the broil and bake. But it isn't heating up.
hotuna
  • 288 Answers
SOURCE: GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Posted on Nov 11, 2007
watugot
  • 290 Answers
SOURCE: OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Posted on Nov 24, 2007
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
  • 7 Answers
SOURCE: KENMORE OVEN C970-417757
possible solution for above...this would apply to any electric oven.
First of all there are two elements.. one for baking (lower) and one for broiling. (upper) . I assume the lower is not working but is the upper.
Unplug the oven. Then remove the element and have a look at and the connections.
I found that on an lolder ovens where I thought the element had burned out that the electrical connections- ( screwed or spade connection) was so badly corroded that electrical contact was poor. I might add that this was also a fire hazzard.
Drudgedread..
Posted on May 10, 2009
  • 8 Answers
SOURCE: Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Posted on Jun 24, 2009
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Oven elements aren't heating, Kenmore Range C970-655821
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 22, 2015 | Kenmore Ovens
No elements working on kenmore range
THINGS TO CHECK:
the broil element
The bake element
Apr 17, 2014 | Frigidaire Ovens
Kenmore md3 both elements stopped working at same time
the broil element
The bake element
Mar 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't heat up on Belling XOU60FSS lights and fan on.
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
2.
3.Even a bad relay door switch will hinder your oven from operating.
THINGS TO CHECK:
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Jul 21, 2012 | Belling Ovens
Frigidaire DGES388DS2 electric single oven
Did you reset the house circuit breaker that supplies power to the oven?
Apr 24, 2012 | Frigidaire Ovens
My broiler doesn't work in my JennAir S136 range and I think the problem is the selector switch. How can I confirm this?
To do that you could check if the correct power is going to broil element.That can by TURNING OFF CIRCUIT BREAKER, remove door by opening to appx 30 degree position where is shold stay open,pull off door,remove broil element and attach a volt meter set to measure at least 240 volts ac and attach the meter leads to the wires on broil element, restore power set controls to broil and check for 240 vac at element. If 240 vac at element it's the element thats defective, if 240vac not present the selector switch is the problem, espically if bake works
Good luck,i hope this helps ya diagnose your oven
Gene
Jul 31, 2011 | Ovens
I have an 8 yr old thermador scd302 double wall oven. Top oven started not heating up (wouldnt go past 240), but then worked a couple of times. Now it just stays at 100. Broil and convection do not work...
THINGS TO CHECK:
the broil element
The bake element
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Oven Won Turn on
May 23, 2011 | Thermador Ovens
Neither the oven or broil element comes on. No error code appears, any thoughts?
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
Mar 02, 2010 | KitchenAid Ovens
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
