Question about Worx Garden
Edger trimmer how to untangle line under axle
  • 9 Answers
SOURCE: I have a GH400 Black
turn it over it must be in backward
Posted on Jul 30, 2008
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
Hy Tech Syst
  • 12 Answers
SOURCE: How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Posted on Aug 31, 2009
  • 640 Answers
SOURCE: Older model Weedwacker Trimmer/Edger with
You will probably have to find someone who has the same model or a different model but has the part that looks the same and get there model numbers. You may just need to take a good look at yours and go to Sears to see if theirs are identical. Then get the model number information and order your parts. You can order by searching Craftsman parts and going to the Sears website and entering the model number and finding the part on the illustrated parts diagram and then look to the list at the right of the screen and find that number to get your part number to order. You will be able to order or if you look at the top of the page (i think) you can call order if you prefer.
Posted on Jul 07, 2011
Testimonial: "What a speedy reply! Thank you for your suggestion. "
emissionwiz
  • 76630 Answers
SOURCE: Troy Bilt edger dies as soon as its under a load--like edging my driveway.
The only real explanation for this is that a tiny piece of dirt has gotten into one of the tiny fuel jets. Remove the carb and blow it out thoroughly with compressed air.
Posted on Nov 23, 2011
Pineapple leaf jammed under spool housing. How to remove housing to clean out?
Usually the cutting heads have a couple of plastic tabs you push in to release the spool from the head
Mar 06, 2016 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
How to untangle inside the spool head ryobi expand it
start with a pair of diagonal cutters .
Sep 13, 2014 | Ryobi Garden
Weed eater line won't advance.
I know it may sound stupid but on the spool their should be arrows that direct you which way to wind the line if you just added line. Some think one goes one way and the other goes the opposite but they both go around the spool in the same way and do not go in the knotches at the top just out the holes. Make sure the spring did not fall out of spool if their is one in that model and while it is running just tap the bottom of the spool on the ground. If that does not work more than likely when you pushed the line back up into the shaft to screw on the knob the line is pinched between the two holding slots. Turn the trimmer upside down (while off) and push knob in and pull line on both sides to advance line. If line does not come out your line is wound wrong or twisted inside spool and must be untangled and reattached. Both lines run the same direction on spool!
Aug 25, 2010 | Homelite Mighty Lite Lawn Trimmer
RYOBI GAS WEED TRIMMER RIPCORD TANGLED
You should be able to take the housing loose with about 4-6 torx head bolts/screws and get in there and untangle the rope. May not even have to take the housing off, just loosen it. Good Luck!
Nov 18, 2009 | Ryobi Garden
Aug 31, 2009 | Black & Decker 14" Grass Hog Xp...
Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Apr 06, 2009 | Black & Decker St7000 13'' Automatic Feed...
How to fit whipper snipper line
Hold the snipper upside down so the petrol leaks onto the kitchen floor. Take 6 metres of line and untangle it eventually. Stick it through the two holes and wind the cord in opposite directions so it jams together and tangles. Stick the unit head back together with two feet of line sticking out each side. Start the trimmer and jump backwards as the line rips itself to pieces. Use it on weeds until line breaks within 20 seconds. Slam the end of the trimmer into the concrete and shout **** fuckey **** ****. Then tear off the head cover and start again. I have done this for years and it never fails. Hope this helps.
Oct 18, 2008 | Garden
Line continues to advance and wrap around axle
I used a file to sharpen the line cutter which controls the amount of line. After sharpening the small cutter on the trimmer, the length of the line is now under control and now my trimmer works just fine.
Sep 13, 2008 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Garden Logo
44 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
