Question about Garden
Removing mower deck attaching snow - Garden
trippssmengi
  • 76 Answers
SOURCE: craftsman riding mower
It should be fine as long as the snow plow is made for your model mower you also might want to look into tire chains for the rear. One thing the plow will not work good for is wet or heavy pack snow but if you keep up with the snow it sould be fine
Posted on Jan 09, 2009
  • 148 Answers
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
Posted on May 21, 2009
SOURCE: Reattach mower deck spring instruction
I have a 13.5 Yardman, MTD I can figure out how to reattach the deck springs? please help.
Posted on Jul 18, 2009
ToolBoxHero
  • 171 Answers
SOURCE: how to remove mower deck
Here is the operator's manual for your mower. http://www.managemylife.com/mmh/owner_manuals/14328/CRAFTSMAN-Lawn-Tractor-L0911505?brand_name_search=917.289101
Page 22-24 shows you how to remove the mower. You will need the manual for the snowblower to mount it to the tractor.
If you don't have the manual for the snowblower go to managemylife.com. Under the manuals tab put in the model number of the snowblower (you will find it on the snowblower and it looks like 123.123456)
You can view, download, and print the manual there.
It is a pretty big job. It will take you about 5 minutes to remove the mower and about 3 hours to mount the snowblower.
Let me know what other questions you may have.
Posted on Jan 10, 2011
rycgl
  • 1545 Answers
SOURCE: Removed mower deck with no problems. Cannot
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Posted on Apr 23, 2011
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower deck removal for riding mower
You need to be a bit more specific. Please post the model number of the tractor and the deck. Things change and sometimes it can be from year to year. Only way to know how yours is attached is looking up the model number to know the year and see the parts diagram.
Mar 20, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
I put my snow blade on successfully, but the tractor does not start now! What to do?
Did it start before you installed snow blade? Did you remove mower deck? If you removed mower deck you probably had to unplug blade safety switch. This is a plug in deal, look underneath and see if it is hanging, there is probably a place on the snow attachment to plug into,or you can jump around it by plugging a wire into each hole. (please note I am assuming it ran good before you installed the snow attachment).Hope this helps.
Dec 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Trying to find how old my 917.271024 craftsman tractor is so I can the right snow blower attachment.
Based on the print date of the Manual from managemyhome.com this mower was manufactured in 1999.
Jan 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Will a snowblower attachment model number 842-240743 fit on my riding mower
i have a snow blower attachment mod# 842.240530 sears and a sears 18 hp tractor mod # 917.258492 with no instructions on how to install them together? i dont know where all the parts go.
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
May 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
