Capacitor c3 68uf 35v - Televison & Video
4 Suggested Answers
  • 8457 Answers
SOURCE: I need a 1200uf 35v radial capacitor
Try website Ebay.com to buy these capacitors.
Posted on Mar 26, 2010
  • 1684 Answers
SOURCE: magnavox 37MF321D/37 power light & screen flash, won't come on.
A full capacitor kit for the 37MF337 and 37MF321 models is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=21_77&products_id=216
The kit contains all 8 capacitors needed to rebuild the power supply board
Posted on Jul 18, 2012
  • 34733 Answers
SOURCE: Upgrading TV capacitors from 1000uf-10v to 1000uf-35v?
Functionally, they are the same.
Posted on Dec 13, 2016
Testimonial: "So, if the capacitor has the same capacity 1000uf will function the same way even if I upgraded both from 10v and 35v to 25v and 50v respectively to increase their work life! Thanks"
32MD251D/37 will not power on
Zack Corpier
Workup for repair
02/22/2013
Diagnosis for Magnavox 32MD251D/37
Symptoms:
Will not power on
Once on, if turned off power might not return
Does not respond to power cycling
Possible Culprits:
Overloaded fuse
Damaged/fried power board
Damaged/fried inverter board
Damage to wiring or related
Overloaded capacitors on power board - I identified this based on a visual inspection and a multi meter test
https://lh6.googleusercontent.com/-Mcf67G5l3l8/USgitModWZI/AAAAAAAACRo/PwjueC45Hjo/w333-h319-o-k/caps.png
Problems Identified:
Capacitor 2079 appears overloaded - 1200uf 35v
Capacitor 2080 appears overloaded - 1200uf 35v
Explanation:
The capacitors referenced regulate the voltage controlling the power. These caps have a limited lifetime in hours which is usually around 3000. The device was left on for an extended period of time overloading these essential components.
Resolution:
1. I will order a set of replacement capacitors
2. Discharge board prior to work
3. Remove and replace damaged capacitors
Required Parts (total cost $30):
(2) Vented axial 1200uF 35v Capacitors - $8
Variable wattage soldering iron (minimum 35w) - $22
Feb 10, 2013 | Magnavox 32MD251D/37 Tabletop Pedestal...
Not turning on at all
check your power supply. remove it then remove the metal plates on top of the psu. ill bet you find 2x 1000uf 35V ,4 x 1000uf 10V and 3x 670uf 35V capacitors that are swollen or leaking. if you replace the 1000uf caps it will work but if the 670uf caps are swollen as well its a good idea to replace them as well. the 1000uf capacitors can be bought at radio shack for around 10 dollars. you can use the 1000uf 35V caps for the 1000uf 10V caps if you cant find the 10V ones . the 35V caps are a little bit bigger but still work . you will need a good soldering iron (35-60 watts) and a good desoldering tool . easy to do if you know how to solder.
Jun 29, 2010 | TruTech PLV16320 Television
My dell w3000 tv wont power on
There are likely bad capacitors on the power board. You will need to replace 4 capacitors, labeled c101, c304, c305 and c404. I used 3 50v 33uf and 1 50v 47uf capacitors. The originals are 35v 33uf and 35v 47uf. Replacing these should fix most power board issues.
Dec 20, 2009 | Dell W3000 30 in. HD-Ready LCD Television
Hitachi 50ux14b. The picture shrinks at the bottom about 4 inches.
This is a problem with the vertical output IC's and associated capacitors. The solution is to replace the IC (usually LA7838) and 2 capacitors (100uF @35V and 220uF @35V).
Sep 19, 2009 | Hitachi 50UX57B 50" Rear Projection...
Magnavox 37MF321D/37 power light & screen flash, won't come on.
Aug 27, 2009 | Philips Magnavox 42MF521D/37 Television
Television will not turn on
ON the Deflection board look at cp150 (2200uf 16v)- if it is puffed up on top it is bad replace it and 2 more cp114 & cp120- 220uf 35v. Radio Shack should have capacitors. they are green with gold writing on them.
HAPPY NEW YEAR!
Dec 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Capacitors
There is 3 capacitors in same circuit 1 will be a 2200uf 16v / (2) of them are 220uf 35v and some sets may have (1) 220uf 35v (1)330uf 35v. replace 3 that are green with gold writing on them. also when reconnecting board make sure you have second ribbon connected good or set wil not come on.
Nov 06, 2008 | RCA D52W19 52" Rear Projection Television
Jvc will not power up
Not, just install soldering stations on the terminal capacitor ( bottom) and pull up slow, clean solder and put it back new one. See position ( -- And + )
C926 and C928 1000uf 35v Common problems.
Some time D905 shorted
Replaced C911 470 uf 35V
Ready!!!
May 10, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
