Routers
Problem for Routers
Generic problem for all Routers
I have a Linksys router and it really dos...
By rcrispin1 on Mar 13, 2009
I have a Linksys router and it really dosn't tell me a lot about hooking it up! Can anyone help? MDL# EZXs55W It is a five port. The tech connected the cable and the eithernet cable to the modem. I tried to connect the second computer to the router with the eithernet cable and a power cord. The only other thing that will connect to the router is another eithernet cable. I have also tried connecting the eithernet comming from my computer to the router as well as the second computer. Then connecting a short eithernet cable from the router to the modem. Nothing so far works.
Thanks
Bob
Comments:
Mar 13, 2009
- Linksys 5 port 10/100 Workgroup switch
GEB1040
I really do not see any other information on it. The unit is not a wireless!
Thank you for your reply1
Bob
Mar 13, 2009
- ver 3 (5 port)
Mar 13, 2009
- The unit is EZXs55W ver. 3 (5-port) I have the router hooked up but it is obviously hooked up wrong as the second computer will not come online. I do not really know where the wires should go!
Thanks.
Bob
Mar 13, 2009
- OK! I am an old guy and sometimes do not understand. So! What I am hearing you say is that the cable from the provider is to be hooked into the modem. Next The jumper wire should run from the modem to the uplink on the router. Then the computers should be hooked to connections 1-4
If I am correct with this statement then I still have the second computer problen not comming online.
Thanks
Bob
Mar 13, 2009
- The linksys link will not come up either!
Thanks
Bob
Mar 14, 2009
- You know I apprecite every thing that you guys have done for me! I finally took the switch box back to best buy and as I told my wife that I was going to strangle the guy, and I discovered that he was much larger than I was! So I just bought a router and it came with a instruction disc that an idiot could follow. I deeply appreciate all of the help that I have received!!!
Thank you all!!!
Bob
Mar 14, 2009
- Thanks so much for all of your help! Very much appreciated.
Bob
Clarification Request
Posted by Joed911 on Mar 14, 2009
This statement is incorrect:
Basically, you need to plug one end of a network cable into the modem and the other into the Uplink jack on your switch. Then plug your computers into jacks 1-4. For some reason Linksys disables jack #5.
Port 5 on the 5 port switch/hub is the uplink port which allows the unit to broadcast IP addresses when it is connectec to a router.
The 5 port switch will not broadcast IPaddresses when hooked up directly to the cable modem. Bob, You need to purchase a router.
The confusion here is that you may be calling the 5 port switch a "router" which it is not. A router ia an appliance that when hooked up to the cable modem, it will broadcast up to 256 IP addresses for 256 computers.You need to purchase a router.
Posted by Joed911 on Mar 13, 2009
If , after you get the router, you need to set the 5 port hub up, let me know.
You need to purchase a router to be able to use more than one computer on the internet. The linksys wireless routers are MDL# WRT54G, WRT54G2 is the newest and faster one.
Or you can purchase D-Link , NetGear wireless routers, check for sales.
Posted by RickOz on Mar 13, 2009
Bob,
There are 3 versions of that router. Can you look at the sticker on the router and let us know which version you have?
Thanks
The MDL# EZXs55W is a 5 port hub, it is not a router. The 5 port hub will not broadcast IP addresses without a router connected to it.
Do you have a separate unit that is a router?
Best Solution
posted on Mar 14, 2009
Very Helpful)
Joed911
Rank: Guru  Computers & Networking  Expert
Rating: 88%, 1735 votes
Great !
But if you have trouble installing the cd, follow these instructions:
Router setup
You do not have to use the cd.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 13, 2009
Not Rated)
RickOz
Rating: 86%, 88 votes
Follow up to Joed911...
I should have checked first. It is only a switch. Here is a link to the install guide from Linksys: http://downloads.linksysbycisco.com/downloads/ezxs55w_qi,2.pdf
let me know if this does not help
Comments:
Mar 13, 2009
- Bob,
Sorry, I thought your modem was also a router. If not my solution will not work.
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
trying to set the router up for gaming haveing a hard time... I have enabled unpn but i still get... (More)
Answer
can not get my wii console to connect to my wireless router. It is a belkin and it keeps asking for... (More)
Answer
how can i put a password on my Encore ENHWI-N2 802.11n Wireless Router?
Answer
D-Link Dir-655 router shows the wrong date and time.
Answer
everytime i try to log on using my belkin g router it ask me for a wep code
Describe your Routers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
