Question about Garden
Looking for the ENGINE manual for a Yardman 20" mower, model #11A-108Q401.
Engine surges.
  • 22 Answers
SOURCE: New MasterCut mower runs erratic & gasoline leak around fuel cap.
as it is a new machine if it has not been p.d.id by dealer it may be that some test fuel residue is in carburettor which is causing this,you need do drain of carburettor of all fuel,remove bowl and spray clean useing either air or carb cleaner spray(should get from local autoparts store) note try to spray up centre of carb as may be a jet up there as well,refitt bowl and make sure you use fresh fuel this should solve problem,with unstable running fuel may be finding a way back through breather at carb with the vibration and may be cured after you have done carb
Posted on Mar 30, 2009
  • 1129 Answers
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
SOURCE: Troy Bilt model 542(11a-542-q711)has Honda 160cc
I need Gaskets for caboretor
Posted on Sep 08, 2009
mowerman1857
  • 389 Answers
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
Posted on Sep 14, 2009
  • 396 Answers
SOURCE: engine speed surges
Surging engines in lawn mowers are usually related to a lean fuel/air mixture. With today's environmental concerns, the carburetors on these engines are set with a very lean mixture (to reduce air pollution). Furthermore, they usually put limiter caps on the carburetors where you cannot easily adjust the mix to get the engine to run better.
If there are adjustment screws on the carburetor, try turning the high speed adjustment screw a bit counter-clockwise (if the limiter cap will allow it). This will enrich the fuel/air mix a bit and might help the engine run a bit better.
Posted on Oct 11, 2009
Testimonial: "Thanks, I think I can figure out which is the High speed jet, it's the other one besides the one that restricts the throttle from going below a level."
Runs rough, Uses LOTS of fuel, not leaking fuel, Starts hard.
turn your set screw at 1 1/4 turns from closed,it is wide open
Jul 19, 2015 | Garden
Bolens 11a 074e065
Empting the gas tank and filling with fresh gas may take care of the problem.
Sep 28, 2013 | Mg International MasterCut 20" 123cc Push...
Were can i get the manual for yard machine 173cc 11A-41MY229
go to mtdparts.com
under the support folder you will find operator manuals click it
enter your model number where prompted
download the pdf file. and thats it
Mar 13, 2013 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Need an engine manual not supplied with new mower just purchased at Home Depot. Yard Machine sent an operators manual but no engine manual. Unit has a B&S ABSXS-1581VG engine, 158cc, SN 10 0518 54...
GET ON YOUR COMPUTER PUNCH IN MAKE MODEL AND YEAR OF YOUR LAWN MOWER THE SITE WILL COME UP THEN PUNCH IN A REQUEST FOR YOUR MOTOR AND IT SHOULD GIVE YOU A MANUAL YOU CAN DOWNLOAD ON YOUR COMPUTER
Sep 29, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
Describe your Briggs Stratton Lawnmower Lawn Mower Short Block Problem. I have model# 11A-414E765 Lawn Mower. Starts ok but is surging and when I checked a brand new spark plug it was full of black dust...
I am pretty sure this is a 4.5 Hp engine with the carb on top of the tank. Plastic carb 4 or 5 mounting screws mating carb to tank. Remove the air cleaner... and tighten the carb to fuel tank mating screws. It is drawing air between the tank and the carb. This should stop the surging. If is has been a long period that you used the mower with the surging problem the diaphragm between the tank and the carb may be either out of position or damaged. The diaphragm is not expensive. Usually the first time this symptom presents itself you can resolve it by tightening the carb to tank scresw. IF you have the primer bulb carb..mash the rubber of the bulb against the carb body. If the surging stops... the primber bulb has a pin hole in it.
You passed the mower model number and not the engine model number. When we use the 11A number you passed all we get is the base and handle parts. If you need more help I need the model number off the engine just above the spark plug wire on the air shroud.
Thanks for choosing Fixya,
Kelly
Aug 31, 2011 | Briggs & Stratton Briggs Stratton...
I have a Yard Machine lawn mower (Model # 11A-41MY229). I lost the manual. When I pull the chord the motor turns but it won't start. It has plenty of gas. Do these lawn mowers have a starter fuse that...
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I have a Yardman 22" push mower Model 11A-084E029 B&S 158 cc engine I bought new. It starts and rungs great the first time I use it. When I go to use it again in a couple of weeks it will not stay...
still your gas could be not good for a small engine like a push mower. check your local content of ethanol in you area. ethanol is very,very,very bad for small engines. ethanol(alcohol) over time creates moisture in the gas and moisture(water) dont burn. I say check you local gas station or go buy gas other place. look around for special gas like for fleet. empty all gas and remove carb. bowl and fill with new gas.
Aug 14, 2010 | Mtd 22" Yard Machine Push Mower
BOLENS, 4,5 HP Model # 90012 PN# 11a-084c163 SN: 10293-31672 We are looking for a manual to know what type/kind of oil and when to do the oil change. We would like to know if we should use only gasoline in...
use 30hd oil in the crankcase about 20 oz., change it about once a year. but check it every time you refuel.
it is a 4 cycle engine so it uses regular gasoline in the fuel tank.
good day.
Nov 18, 2009 | Garden
Oil for yardman lawn mower
May 27, 2009 | Mtd LAWN MOWER PART # 782-0082A-0638 DECK...
Yardman lawn mower (sorry about the "stroller" thing)
yard man lawn tractor steering problem
Apr 14, 2008 | Baby Gear
Garden Logo
24 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
