Question about Toshiba Qosmio Computers & Internet
Burner error code 380381 26 2a040990 - Qosmio Toshiba Computers & Internet
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
My burner stopped burning cd's in iTunes and Windows Media Player.
This may either be due to the software you are using or to the hardware. Start with upgrading your burner's driver. If this does not help, try upgrading the firmware of the burner. If the firmware upgrade procedure fails, it gives you an error code. Look up for this error code on the internet.
Oct 25, 2013 | ASUS K53E-BD4TD 15.6in Laptop i5 2.4GHz...
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
Code c4-13
Before calling service technician, open following link for Rheem troubleshoot resources including error codes, Rheem chat, and possible manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting.
Error code C4 13 is bad oxygen sensor, inadequate incoming air supply, or bad venting. Also bad PC board, or internal wiring, or temperature set too high, damaged burner parts.
http://waterheatertimer.org/pdf/Error-code-13.pdf
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Tankless require yearly maintenance to combustion chamber and burner parts.
Prescribed maintenance can correct some of the issues in error code 13.
Jun 25, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
When running test on my Dell Vostro 1500, error code 0146 shows
Error 0146 is a failed hard drive or bad drive sector, you have a bad hard drive,
Mar 04, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
GE Profile smooth cooktop F113 error code
check service manual and see what it say about err f113 or call service
Jan 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
New Mac ibook
I would suggest that you take it to the apple store and they should be able to fix it for you.
Jan 10, 2009 | Pacific Digital (U30274) DVD±RW...
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
i had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
weddie2006@univision.com
Jun 20, 2008 | Toshiba Computers & Internet
Sony vrd-vc20
a code 10 error refers to a hardware failure, where the dvd cannot be communicated with due to it being faulty.
Aug 17, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Computers & Internet Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
