Question about LG Optimus T P509 Android Smartphone, No Contract, T-Mobile
Fastboot fix
Stuck in fastboot udc
I have a stream tablet it's stuck on fastboot mode how do I get it to power back on
Do a hard reset, and it should default back to normal boot mode.
Jun 17, 2017 | Cell Phones
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
Why is my tablet Stuck on entering DnX mode.Waiting for fast boot command...
my next book tablet is stuck in dnx fastboot mode, it will not unlocked, and it stuck on voice command
May 12, 2016 | Nextbook Premium 8 Se Android
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
https://www.kingoapp.com/help/fastboot-mode.htm
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
May 11, 2016 | Tablets & eReaders
I can not reset my tablet to factory reset no matter how many times it will not work
Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website;
www.adbdriver.com/downloads/
or click on link below for direct download.
ADB Driver Installer (9.22 MB)
next, install the ADB driver then you will see a USB root on notification area on your PC.
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-0.jpg next, download the fastboot click on link below;
https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-2.jpg next, command prompt will open and you need to type these commands;
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-5.jpg This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
that is all; your tablet will be completely restored...
thanks and good luck.
Jan 26, 2016 | Supersonic SC-91JB 9-inch Android 4.1...
Lenovo Tablet a8-50 is stuck in fastboot mode..can't turn on or off
if you able to take out the battery then remove the battery and reseat the battery, it will fix the issue (hope the battery has outside access). Hope it will help.
Nov 23, 2014 | Lenovo A8 50 8" Android 16GB 1GB
How to hard reset my supersonic tablet
www.adbdriver.com/downloads/or click on link below for direct download.
ADB Driver Installer (9.22 MB)next, install the ADB driver then you will see a USB root on notification area on your PC.
No comment next, download the fastboot click on link below;
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
Jul 03, 2014 | Supersonic 7" Touch Screen MID Tablet
I'm stuck on the fastboot mode. how to turn this off?
Its under system / developer options settings just untick the fastboot option.
May 12, 2014 | ASUS MeMO Pad HD 7
Acer stuck in fastboot
Good Day!
Try to sync it in your computer desktop, and reset the setting of your tablet.
Mar 05, 2013 | Acer Iconia Tab A50010S32u Notebook
LG Optimus T P509 Android Smartphone, No Contract, T-Mobile Logo
16 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
