Question about Pentax Optio SV Digital Camera
Pentax Optio SV tunrs off immediately
After FULL recharghing my battery, I took two pictures. Then, I turned the camera off. Two minutes later, trying to open the camera, it turns on, shows the Optio logo, and 2 seconds later tunrs itself off. The lens doesn't even attemt to open. We've trieds all capture modes - but still - the camera won't open... Any idea? Thanks!
  • Anonymous Nov 29, 2008
    My camera worked fine then one day it stopped turning on. I thought it was the battery that had died so bought a new one, but that didn't work too. I then thought it may be the battery charger failing but an electronic meter check said the battery was fully charged. My only thought now is the camera, but I don't know where to start.
    All advice welcome.
  • 641 Answers
I have the same problem with my camera and the following activities solved it. Remove batteries and clean contacts of battery's host (include cover). Check as well that contacts are not bended and didn't lost their springiness. Good luck !
Posted on Aug 06, 2007
SOURCE:
Why my camera turns on but then turns off again immediately. Have replaced battery but it did not fix problem
Try cleaning the contact of the battery and the camera, and make sure its making solid contact.
Mar 02, 2015 | Pentax Cameras
My Pentax Optio S5z locks itself somehow. Before it usually unlocked on it's own also. Now it is stuck on LOCK and I am not able to delete pictures, or use the MENU or MODE buttons. I am able to take...
Is the slide switch on the side of the card in the unlocked position? If so, try this...remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 28, 2009 | Pentax Optio S5z Digital Camera
I want to post images of recipes to Evernote --image is backwards
I cannot for the life of me understand why your pictures are coming out backwards. When you take a picture of a person pointing to the left, does the picture come out with them pointing to the right?
Nov 09, 2009 | Pentax Optio SV Digital Camera
Pentax Optio A40 Turns Off
we are having the same problem. Did you ever get yours figured out?
Mar 25, 2009 | Pentax Optio A40 Digital Camera
Pentax Optio E60
Alkaline batteries ONLY. I did the cheap thing too, that happened to me.
Jan 17, 2009 | Pentax Optio E60 Digital Camera
My Pentax Optio E40 Camera
The built-in memory only has about 8 pictures or so. You have to buy a memory card to insert in the same section where the batteries are inserted.
Apr 03, 2008 | Pentax Optio E40 Digital Camera
Digital camera problem
The battery should be a common format with a Pentax label. There is a possibility it could be card fault. But before you rush out to buy a card[not a bad idea to have two cards though] Contact Pentax Tech Support site - this may be an on going issue- and the camera is young enough to be swapped under warranty.
May 16, 2007 | Pentax Optio S4 Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Optio SV - Date/Time problem
I think it is pretty obvious that your camera isn't going into full 12 hour mode and is displaying a combination of 12 hour (am/pm) and the usual 24 hour time. This could not come from anything other than a firmware error, and will be common to all SV's with the same firmware version. Almost certainly Pentax will fix it with a firmware update within the next few weeks to a month once they know about the problem. So you've proved that the problem is in the review mode in the camera. Is it also embedded in the date for the file and in the EXIF information included in the file? I guess that if 24 hour time works, the temporary fix might be just to use 24 hour time.
Sep 08, 2005 | Pentax Optio SV Digital Camera
Pentax Optio SV Digital Camera Logo
124 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
