Question about Black & Decker BDL400S Bullseye Crosshair 90 Degree Auto Leveling Interior Line Laser
Cheat level up in idate
I like to up my level.thanks po
My honda accord 2008-v6 has code po 847.please tell me what does this code mean & how to fix it? thank you.
PO 847 relates to transmission fluid pressure, could be several faults . fluid level, transmission oil filter, oil needs changing, converter fault oil over heating ECT.
Mar 03, 2016 | Honda Cars & Trucks
Help po plsssss
you mean flooded ang egine mo? adjust your float or clean your carb. it seem na your float on your carb is not closing when it reach a certain level.
Jan 08, 2014 | 2007 Sym Magic 110 RR
Trouble codes po 760, po 755, and po 134
Sounds like the oil level in the gearbox is low ,if it has a dipstick then start engine and chock wheels ,put in reverse with engine running and check oil level
Jan 04, 2014 | 2001 Mitsubishi Montero Sport 4WD
My 2000 has codes po171 po300 po 463 po480 what
P0171 =system too lean (bank 1)
P0300 = multiple misfire
P0463 = fuel level sensor circuit high input
P0480 = cooling fan 1 control circuit
Aug 16, 2013 | 2000 Oldsmobile Silhouette
Isa rin ako sa mga nangangarap na maging star ng GMA nais ko din maging artista hnd lamang para sumikat kundi gusto ko din maging modelo sa kapwa ko kabataan mahusay din po akong umarte a may talent...
ako rin gusto kong maging artista ito ang pinaka pangarap ko sa buhay sana tulungan nyo po ako pls. lng po kung sino po ung mga director n mkabasa nito tulungan nyo po ako sa drama po
Sep 02, 2012 | Spongebob Squarepants Comforter
Good morning po ask ko lang po..sharp t.v model 21v-L330XB , marami po guhit naresoldered ko na po yun mga angat sa c.r.t ,hindi parin po matanggal ang mga guhit. anu po kaya pwede maging solution dun.?...
Ikaw ay pakikipag-usap tungkol sa vertical na problema lenearity ko Ipinagpapalagay at i-post ito solusyon.Lamang palitan ang lahat ng mga electrolytic capacitors sa vertical seksyon ng circuit output.May 4 o 5 ng mga ito.Palitan ang lahat sa isang pagkakataon
Apr 17, 2012 | Sharp 25R-S100 25" TV
Paano po mkkpg install ng operamini o uc browser s samsung b5722.gusto ko sn xyang lagyan.tnx po
Download Opera Mini Browser here : PINDOT MO AKO
Just follow the procedure, napakadali lang po i-install ito, pwede po sa computer,memory card or direct na po sa phone ninyo,pag-click po ng download button, specify ninyo lang po ang model type the sundin ninyo lang po ang susunod na instruction.
sana po makatulong,thank you for visiting fixya.
Jun 29, 2011 | Samsung B5722 Cell Phone
AC has freon but it quits and starts blowing hot air then it has a blue thermostat symbol on dash has 2 codes po 128 and po 118
Both codes are for the coolant temp, the blue symbol means the car is cold, check the fans to make sure there operating and check coolant level
Jun 21, 2011 | Volkswagen Beetle Cars & Trucks
2000 chevy truck 1500. I have 3 codes the computer is telling me po404, po405, po463
PO 404 exhaust gas reciculation circuit, range or performance problems
PO 405 exhaust gas reciculation sensor circuit low
PO 463 fuel level sensor circuit high input
Dec 04, 2009 | 1999 Chevrolet Silverado 1500
How to find hidden menu on yeasu 857d
Note: The following was taken from a web site as follows:
http://www.kb2ljj.com/data/yaesu/ft-857.htm
WARNING: changing these will reset all the memories.
I want to warn you do not change these values unless you are sure of what you are doing. To get them turn transceiver off. Press and hold the A,B,C keys; while holding them in, press and hold in the [PWR] switch for 1/2 second to turn the tranceiver On. Now let go of all keys. Attention, for menu NO-017. Input voltage 13.8V = 138 to calibre voltmeter.
Press F key to finish.
Function Setting in my radio
============================================================= Adjust-No Function Setting Mode Frequency ============================================================= NO-001 HF1-RXG 118 CW 1.800.00 NO-002 HF2-RXG 91 CW 7.068.19 NO-003 HF3-RXG 133 CW 21.225.13 NO-004 50M-RXG 106 CW 50.000.00 NO-005 VHF-RXG 77 CW 145.437.50 NO-006 UHF-RXG 103 CW 438.900.00 NO-007 SSB-S9 61 CW 21.225.13 NO-008 SSB-FS 54 CW 21.225.13 NO-009 FM-S1 68 FM 145.437.50 NO-010 FM-FS 99 FM 145.437.50 NO-011 DISC-L 50 FM 145.437.50 NO-012 DISC-H 79 FM 145.437.50 NO-013 FM-TH1 100 FM 145.437.50 NO-014 FM-TH2 100 FM 145.437.50 NO-015 FM-TI1 10 FM 145.437.50 NO-016 FM-TI2 10 FM 145.437.50 NO-017 VCC 138 FM 145.437.50 NO-018 HF1-IC 83 CW 1.800.00 NO-019 HF2-IC 80 CW 7.068.19 NO-020 HF3-IC 87 CW 21.225.13 NO-021 50M-IC 84 CW 50.000.00 NO-022 VHF-IC 72 CW 145.437.50 NO-023 UHF-IC 74 CW 438.900.00 NO-024 HF1-PO-MAX 165 CW 1.800.00 NO-025 HF1-PO-MID2 105 CW 1.800.00 NO-026 HF1-PO-MID1 31 CW 1.800.00 NO-027 HF1-PO-MIN 13 CW 1.800.00 NO-028 HF2-PO-MAX 159 CW 7.068.19 NO-029 HF2-PO-MID2 102 CW 7.068.19 NO-030 HF2-PO-MID1 29 CW 7.068.19 NO-031 HF2-PO-MIN 11 CW 7.068.19 NO-032 HF3-PO-MAX 158 CW 21.225.13 NO-033 HF3-PO-MID2 101 CW 21.225.13 NO-034 HF3-PO-MID1 29 CW 21.225.13 NO-035 HF3-PO-MIN 11 CW 21.225.13 NO-036 50M-PO-MAX 145 CW 50.000.00 NO-037 50M-PO-MID2 92 CW 50.000.00 NO-038 50M-PO-MID1 47 CW 50.000.00 NO-039 50M-PO-MIN 8 CW 50.000.00 NO-040 VHF-PO-MAX 87 CW 145.437.50 NO-041 VHF-PO-MID 43 CW 145.437.50 NO-042 VHF-PO-MIN 7 CW 145.437.50 NO-043 UHF-PO-MAX 112 CW 438.900.00 NO-044 UHF-PO-MIN 16 CW 438.900.00 NO-045 HF1-TXG 48 USB 1.800.00 NO-046 HF2-TXG 38 USB 7.068.19 NO-047 HF3-TXG 43 USB 21.225.13 NO-048 50M-TXG 40 USB 50.000.00 NO-049 VHF-TXG 47 USB 145.437.50 NO-050 UHF-TXG 49 USB 438.900.00 NO-051 ALC1-M 203 USB 21.225.13 NO-052 ALC-M 85 USB 21.225.13 NO-053 HF1-REV-ALC 61 CW 1.800.00 NO-054 HF2-REV-ALC 56 CW 7.068.19 NO-055 HF3-REV-ALC 50 CW 21.225.13 NO-056 50M-REV-ALC 47 CW 50.000.00 NO-057 VHF-REV-ALC 62 CW 145.437.50 NO-058 UHF-REV-ALC 57 CW 438.900.00 NO-059 CW-CAR-LEVEL 144 CW 21.225.13 NO-060 AM-CAR-LEVEL 125 AM 21.225.13 NO-061 DEV-W 216 FM 145.437.50 NO-062 DEV-N 110 FM 145.437.50 NO-063 MOD-MTR 200 FM 145.437.50 NO-064 DTMF-DEV 10 FM 145.437.50 NO-065 CTCSS-DEV 233 FM 145.437.50 NO-066 DCS-DEV 168 FM 145.437.50 NO-067 LSB-CAR-POINT -7 LSB 21.225.13 NO-068 USB-CAR-POINT +5 USB 21.225.13 NO-069 VSWR2 at 10W 17 CW 14.257.90 NO-070 VSWR3 at 10W 42 CW 14.257.90 NO-071 ATAS-TEST LSB 14.257.90 NO-072 AMTR-TEST LSB 14.257.90 NO-073 HTEMP-THRESHOLD 38 LSB 14.257.90 NO-074 FTEMP-THRESHOLD 102 LSB 14.257.90 Hope thia helped........kevin KC8IDG
Oct 21, 2008 | Radio Communications
Black & Decker BDL400S Bullseye Crosshair 90 Degree Auto Leveling Interior Line Laser Logo
22 people viewed this question
Top Black & Decker Measuring Tools & Sensors Experts
Vuk B
Dennis
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
