Question about Kitchen Ranges
Allenzi stove knobs pealing - Kitchen Ranges
Why wo't two of the knobs on my kitchaid GAS STOVE WILL NOT TURN
Take the knobs off and look inside. Compare them to the good knobs for any differences. reseat them back on and try pushing the knobs in while turning. It may be a child safety feature.
Feb 20, 2016 | Kitchen Ranges
Which is the lower setting on Thurcroft calor gas stove
I am not familiar with this stove but I think you could turn on the stove and look at the flame while you turn the knob to see which way is high or low.
Jan 07, 2015 | Kitchen Ranges
How to remove the knob
the center of the front of the knob should have a small hole with a screw in it. This is covered over with a \'sticker\' for estetics. peal the sticker at the edge and pluck it off to expose the screw.
remove the screw and gently pry the knob off of the switch.
Mar 23, 2013 | Food Mixers
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Hi I have just moved into a house with an Allenzi upright stove/oven and the oven functions have rubbed off. Is there anywhere I can get a new manual for it or a photo of the dial? I keep burning the...
http://www.allenzi.com.au/downloads/AWEM9U.pdf
Copy and paste into your browser for the oven download manual. Please rate my solution it is how i earn my achievements. Thanks in advance
Apr 13, 2012 | Ovens
We have an old O'Keefe and Merritt stove in a
on most stoves where gas line connects around back should be a gas shut off valve if none put one on
Jun 06, 2017 | Kitchen Ranges
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
