Question about Stoves Ovens
Kenmore model 790.95032505
Oven does't work won't get hot
5 Suggested Answers
SOURCE: the oven won't work, the
Hello Kevin,
Please replace the coil of the oven
Also call any oven specialist to inspect the coil.
Doing yourself may damage more, also whch may cost more.
Posted on Apr 28, 2011
mc1bean
  • 3053 Answers
SOURCE: My daughter has a kenmore stove and oven won't
Hello, Lynda
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and fartherback, It appeared that no one answered some of them, So, I thought Iwould take some of my personal time to see if I can help. Even though this sitemay not have your exact model or brand, this link will help you tons. Here is alink to about everything you want to know about your oven, from
repairto trouble shooting it. Even pictures and video's. Just scroll around and youwill see tons of information to almost any question you might have on yourOven. If you go to this link and click around, I am sure you will find out somuch about your oven, you will know more than the company that made it. Thegood thing about this link is, then you can make the decision of DIY or hiringa pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of myexpertise for other problems you might have in Automotive,Appliance, andElectronics. Drop In anytime for my help. Thanks, Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
machinetech7
  • 1344 Answers
SOURCE: Kenmore Electric Oven won't bake after using self-clean!
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort. Now comes the bad news, you fall under the catagory of damaged electronics. The control has been damaged and I wouldn't doubt if the sensor as well.The part number for the control is WB50T10056 and cost about 108.20. The sensor part number is going to be WB21X5301 and cost about 94.00 On the second part I would call my local parts distributor and as if there is a sub part for it and self yourself about 50 bucks or so. Sorry, and good luck.
Posted on Apr 29, 2012
  • 13 Answers
SOURCE: my oven gets too hot and won't turn back down
Sounds like a problem with the oven thermostat. You will need to meter check it and see if it is closing at all. If not replace the thermostat.
Posted on Nov 08, 2012
Oven won't heat up
What is the complete model number of your unit?
Feb 18, 2013 | Kenmore 24" Self-Clean Wall Oven 3055
My oven gets too hot and won't turn back down
Nov 08, 2012 | Moffat Ovens
Tappan gas oven won't stay hot
bad flame sensor or check gas pressure
Aug 24, 2017 | Tappan Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven just beeps when i turn it on
Hit stop clear then reprogram oven If that won't work unplug for a short time plug back in and see if this works. It found a fault code in the oven control and if you can't reset it. You will have to order a new one. Go to managemylife.com if you need to download manual
Dec 09, 2011 | Kenmore Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
How can we calibrate the oven temperature?
Older oven or newer oven? Old school ovens have a screw in the hollow stem yall can tweak. The new ovens have a themobilian_2771.jpgsensor.
If your oven has a sensor it should read around 1100 ohms at room tempt. If it is out of spec, shorted to frame or open then the fancy shocktronic oven control won't know what the oven temp is.
If you want a great answer post a make and model.
Aug 06, 2011 | Kenmore Ovens
Says oven door is locked...it is not. none of the buttons respond and oven won't work. stove top does work. what could be the problem?
I had the same problem with my oven.Mine is a different make and model but try by opening your ovenand move your locking lever for cleaning look at the actuall hook that locks it and find where on the oven itlocks into sometimes there is a safety switch in that hole that gets stuck.Try by messing with the safety switch with a screwdriver or something to see if the door off light goes off.Good Luck.
Jul 17, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Model No. 362.72505890 Gas oven will not get hot. The element comes on but the burner will not fire up. It did this last weekend but after rotating the temperature knob a few times it finally got...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 30, 2011 | Kenmore Ovens
My Gas stove Kenmore Model #362.75471690 The
you need new glow coil for over it may looklike its working glowing orange but it isnt getting hot enough so you neeed replace it
Feb 03, 2010 | Ovens
Ovens Logo
22 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
