Question about Garden
Where can I find a wiring schematic for a Dixon ZTR 3303 ignition switch
  • 61 Answers
SOURCE: where on the Dixon ztr 5421 do you check the
there should be a sight glass or a dip stick in the
hydraulic tank.
Posted on Sep 06, 2009
Dolfoff
  • 148 Answers
SOURCE: Dixon ztr 311 The left lever will not make the
The motion drive design is similar to a set of spider gears, except it uses friction material rather than bevel gears in the cluster. The friction material may be worn down to the point that it no longer engages and needs replacement. This is a likely scenario for the symptoms you describe.
The replacement procedure is a rather involved process. If you feel confident and are VERY handy, reply to this post and I'll be happy to go into detail.
Hope this helps!
Posted on Oct 01, 2009
Testimonial: "Thanks, lots of help. Details would be great"
  • 3074 Answers
SOURCE: I have a Dixon 44/22
http://www.jackssmallengines.com/pdf_documents/Dixon/422_owners_manual_1981-1982.pdf
Posted on May 08, 2011
rycgl
  • 1545 Answers
SOURCE: Our local Dixon dealer does
I hope these folks can get you to where you need to go.
http://www.lawnmowerpros.com/Dixon/Dixon-Manuals.asp
Posted on May 12, 2011
  • 32 Answers
SOURCE: how do i replace a bearing on my center pulley on a dixon ztr ram 44?
if its for the blade spindle it comes as an assy. no replaceable parts
Posted on Apr 14, 2012
On my 2003 Dixion ztr 3303 then I push both handles forward equally the mower goes off to the right. Also it is like the right wheel has more power than the left wheel, any idea on how to fix it.
The drive unit needs to be adjusted. This unit uses the "Cone Style" drive system. These are extremely difficult to adjust or repair. If you have a Dixon dealer in your area, I recommend him doing the adjustment.
Nov 27, 2017 | Garden
Dixon ztr 46 fuse blowing when ignition switch put in start.
Bad starter windings or grounded hot wire to starter.
Sep 09, 2017 | Garden
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
Dixon ztr 3303
Replace ether the bendix gear assembly(the part thats sticking or replace the entire starter.
Aug 21, 2013 | Garden
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
