Question about Mach Speed Eclipse 180 MP3 Player
Songs only show up in unknown artist folder - Mach Speed Eclipse 180 MP3 Player
I have a Coby MP620-8G mp3 player. For some reason, I've been getting a whole bunch (at least 15 albums) of my artists thrown into the Unknown Artist category, making it difficult to find songs. In my...
I just had this problem as well. Find one of the files that is showing up on the MP3 player as "Unknown Artist" in your iTunes library. Right click that song/file and click "Get Info". You'll most likely find that the song is an "ACC Audio File" which happens often when you copy CDs or download from the iTunes Store. Close the info window about the song and then you can select the entire album or individual songs from your iTunes playlist that are showing up as "Unknown Artist". Once all the songs that you need are selected, right click again and select "Create MP3 Version". This will create a duplicate, however, so you'll want to go back to the main library in iTunes (or stay there if you are already there) and then remove the original "ACC" versions. You can, if you'd like, keep them on your hard drive, but you really don't need them because MP3 is the standard. From here you can remove those files from the Coby MP3 player and replace them with the new MP3 versions you have created in iTunes.
I hope this helps!
Aug 09, 2010 | Coby Audio Players & Recorders
Plays six of twenty mp3s and the rest come up as
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete
Labeling Unknown Songs: open Windows Media Player and go to library click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then sync with your sansa or media player then load songs to it........
Jul 27, 2010 | SanDisk Sansa e250 MP3 Player
MP3 FILES LISTED AS UNKNOWN
Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your sansa or media player then load songs to it........
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
I've never used an MP3 player before. I bought
Sync to your windows media player....Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar click Choose Columns put a check next to Genre, Rating, artist and album artist whatever you want. Right click song under artist and edit same with album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your media player then load songs to it........Or drag and drop
Apr 07, 2010 | Coby MP300 MP3 Player
I can't add new music folders to my sansa e260 because some go to
open windows media player and goto libary click on album artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... then syc with your sansa then load songs to it........
Mar 24, 2009 | SanDisk Sansa e260 MP3 Player
Insignia sport 4 gig wont organize by artist
You will need to right click on the song file to see if the ID3 information is present.
Right-click, Properties, Summary tab.
You shoudl see a list of fields that you can populate manually, or you can try loading your audio files into a media manger program like iTunes, Media Monkey, WMP, etc and insure your song titles and album names are correct in the ID3 tag fields. Then, your files will appear correctly on your player.
Hope this helps!
Nov 01, 2008 | Insignia Sport MP3 Player
Putting music in seperate folders
Hm, Tricky. Are they un-named in the Unknown artists folder? I know what you're talking about though.. Maybe if you try putting them in the correct folders in your computers Music folder. Like.. All the 28 days later songs go into the 28 days later soundtrack folder (If you don't have one, it's easy to make a folder for stuff.) When you open up your music space of your computer, the part where it says File and Folder Tasks. First thing it says in this box is, Make a New Folder. Easy. So, you make a new folder and place all the music for that cd in it. (If it already isn't) Then make sure they all have the correct artist name and stuff.. Any way.. I hope this helps, but I can barely understand it.. Any way..
Oct 18, 2007 | Philips HDD1630 MP3 Player
Unknown Artist e270
you downloaded a corrupt file, you need to trash everything and restart it from scratch, reformat it, the whole nine yards. you have to be careful when you download from placed.
Aug 05, 2007 | SanDisk Sansa e270 MP3 Player
Artist showing up as unknown
In the cd's the artist isn't named and if you want the artists names you need to right click with your'e mouse and click rename, type the title and then the artist.
Jun 01, 2007 | SanDisk Sansa m240 MP3 Player
Artist and Album folders/ tags showing "Unkown"
Ok I'm not sure about this one, but try and find out if the playlist are protected cos if they are it wont show up on your player. other wise contact samsung for support (www.samsung.com)
Jun 06, 2006 | Samsung Yepp YP-T7JZ MP3 Player
Mach Speed Eclipse 180 MP3 Player Logo
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
