Question about Google Android
Screen wont turn off in lock
When i press the red turn off button the screen turns of then it goes to the press menu to unlock.
    Problem Solver:
  • 6 Answers
Hold the red turn off button until a menu shows up and choose turn off.
Posted on Mar 16, 2009
SOURCE:
I can't unlock my osd screen, tried everything
While holding it, turn the monitor on. Once the monitor is on for a few seconds, let go of the "left" button. Your OSD should be unlocked. This is how it works to lock press and hold the MENU button while the monitor is off and then press power button to turn themonitor on.
How to unlock the OSD of an AOC monitor - Quora
https://www.quora.com/How-do-you-unlock-the-OSD-of-an-AOC-monitor Feedback
About this result
How to unlock OSD my HPx20 LED wide screen monitor?.. - HP Support ...
https://h30434.www3.hp.com/...Lockup/...unlock-OSD-my...screen-monitor/.../74766... Jul 4, 2011 - Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD. "Power button is locked" message - HP Monitor 27es
Aug. 31, 2017
OSD Lockout on HP Pavilion 27xi - how to unlock?
Apr. 5, 2017
HP monitor Main Menu / OSD Lockout cycle continuously
Jul. 9, 2009
More results from h30434.www3.hp.com
HP LCD and LED Monitors - OSD Lockout Message Appears on the ...
https://support.hp.com/ca-en/document/c01932183 What to do when an OSD Lock out message opens. ... OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
display - How do I lock and unlock the OSD of a "AOC monitor 21 ...
https://superuser.com/.../how-do-i-lock-and-unlock-the-osd-of-a-aoc-monitor-21 Aug 29, 2009 - OSD Lock Function: To lock the OSD-First make the Monitor off by pressing power button and then hold the Left button for 5 seconds and simultaneously hit the power button with the left button and the osd is Locked. If your AOC e2343F is locked then just power off your screen and hold power and menu buttons together.
can unlock my osd screen Google Search
Jun 12, 2018 | Cars & Trucks
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
The brightness icon stays on my screen
May need to do this with if off (OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.)
Oct 31, 2010 | Office Equipment & Supplies
The OSD Menu on the monitor itself is locked. How do I unlock it so I can adjust my settings? It was given to me, I have no printed material for it. Thanks
Turn off monitor, hold down the menu button, turn the monitor back on, release the menu button after 10-20 seconds. Your Iiyama screen will now be unlocked.
Mar 07, 2010 | HP M700 Monitor
How can I unlock it (Audiovox tv)?
you need to search your universal remote code for a audiovox code try all of the audiovox codes then once you find the right one, how you will tell is when you turn the tv off and on click menu then unlock the tv
Aug 08, 2009 | Audiovox Televison & Video
My screen went blank. When I power up, the SANSA
Press menu button for 15 then it turns off .. after that .. turn it on again
Jul 12, 2009 | SanDisk Sansa e260 MP3 Player
Help unlock child lock on tv.
The solution is so simple!
Press the POWER (RED) button and the TV/AV button simultaneously - hey presto! the child lock will switch off and you will have your TV back working properly.
May 29, 2009 | Philips Magnavox 27MS343S 27" TV
Sharp LD-26Sh3U menu locked
RELEASING THE ADJUSTMENT LOCK
Perform this procedure using the buttons on the TV.
1: Turn off TV
2: While pressing the "MENU" button press the "POWER" button continue to press the buttons until "UNLOCK ADJUSTMENT" appears on the screen.
3: Press the "VOL >" button.
That's it you may have to turn the unit off then back on at the end of step #3.
May 18, 2009 | Sharp LD-26SH3U 26 in. LCD Television
Monitor control lock problem
Replace the small 78L05 regulator 5V supply to micro.
Jan 13, 2008 | Computers & Internet
Bush Video Dvd combo Dvrhs02 Lock Code
Turn the unit on then press the 'vcr/dvd' and 'disc menu' buttons on the unit together and hold down until the unit reboots
Jan 03, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Google Android Logo
79 people viewed this question
Top Google Computers & Internet Experts
Peter Dragonetti
Colin Stickland
Colin Stickland
George Etukudo
George Etukudo
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
