Question about HP PSC 2410 All-In-One InkJet Printer
Cracking sound when the printer is powered and switched on, it makes a cracking sound endlessly and will not innitialise.
I have posted my solution to exactly the same problem on this site. Please look for it.
Posted on Aug 14, 2007
    Novelist:
    Champion:
  • 254 Answers
This is apparently a common problem. Take a look here http://www.fixyourownprinter.com/forums/printer/36708
Posted on Aug 06, 2007
SOURCE:
I need to check my wiring hook up on my hp computer, how can I MAKE sure its properly connected?
no computer stated
no purpose stated (endless usages for puter) endless.
most folks today , live in the IE11 Browser? that you reading mail. only?
wiring well the PC has manual,
the PC is HP,
the PC manuals at HP cover all that, see quick setup guide.
what PC"? name it.
sounds like some desktop PC from HP.
they made them for over 30 years.
vast models. but have just the need for 3 cables.(wires)
power wire, to the wall. to PC.
VGA CABLE from PC to Monitor
and power wire or power pack to monitor.
then push power on , on both, and watch the smoke !
Dec 01, 2017 | HP Computers & Internet
LG 42LD560 LCD TV
mainboard failure
I suggest you change tha flash memory .
This would be the first thing to try
Jul 11, 2014 | LG Televison & Video
My hp scanjet G2410 makes a cracking noise when scanning
A jammed or broken tooth on a gear will cause cracking sound. And will continue until you shut off power. The reason the sound continues is because it's still in the process of scanning and hasn't reached the white tape which the sensor senses to return to the finished position. An HP scanjet just as its printers don't have a sensor to stop the carriage from moving until the job is completed. Further use will ultimately cause a loud pop and cause further damage.
Jun 12, 2012 | HP Office Equipment & Supplies
PANASONIC DMR-ES20D.CLOCK FLASHING 000. SWITCH ON SAYS HELLO, THEN GOES TO U81. SWITCH OFF SAYS BYE, THEN BACK TO CLOCK FLASHING 000. thanks
The DVD Rom is not innitialising. That could be due to the +5Volt supply being missing or the mechanism is blocked or the laser cannot return to the start position.
Jan 31, 2011 | Televison & Video
Printer is making clicking sound after dropped to the floor
Possible that you would have damaged the printer harware inthe fall. So in the first place remove the power supply and check for crack inthe board. If the power output is showing the required DC, the checck the main mother board for cracks, checck using magnifier and resolder suspected joints.
Sep 08, 2010 | Lexmark X2600 InkJet Printer
What is the default password for the Lexmark T614?
There is now default password. The default is without password. Did you try a cold reset?? Push and hold down butons 2,3 and 5 while powering on the machine. Release the buttons when innitialisation is on the display.
Gerrit jan
Nov 04, 2009 | Lexmark Optra T614 Laser Printer
My printer somehow has gotten offline. I have
try reinstalling printer then switch it on before u switch on u comp.
Jun 06, 2009 | Brother MFC 490cw Color Inkjet...
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Apr 28, 2009 | HP DesignJet 750c plus InkJet Printer
Canon NP-6035 persistent E002
There is a heating problem connected to the fuser. It could be the heater lamp or thermal switches. Lamp is most likely.
Aug 27, 2007 | Canon NP 6035 Copier
HP PSC 2410 All-In-One InkJet Printer Logo
137 people viewed this question
Clive
Clive
Thomas F. Schneider
