Question about Kenmore 96212 / 96214 / 96219 Electric Kitchen Range
Stove top There is a warning with beeping sound that says "F1 ERR " and a picture of a lock with the word "CLEAN" appears even though we are not using it. We tried pressing the cancel button but nothing happens so we pull the plug
  • Anonymous Nov 06, 2007
    I have the exact same problem. I actually tried to clean my oven, and two minutes later I saw the error message. We unplugged it and the error message remained;
    Scholar:
  • 161 Answers
Some of these reqire you toclean them at certain intervals to make youkeep it maintained You might have to do just that before it will reset itself.
Posted on Aug 07, 2007
SOURCE:
How to stop beeping noise on my stove? Can I use the top of my stove?
Try turning breaker off for 2 minutes then back on. That may clear the code. Top elements should work independently of oven control
Sep 20, 2018 | Frigidaire Kitchen Ranges
Tip
Please help. We are a cleaning crew that went to a client's home to do a reno...
If you are having oven problems with your GE XL44 oven then you need to do a bit of oven troubleshooting. The first part of that problem is to know what the oven fault codes are trying to tell you.
The codes F0, F1, and F7 could either be a problem with the control or the keypad.
-to see what the problem is cause by, push clear/off on the keypad. Then disconnect the ribbon connector from the control. Wait at least 35 seconds to see if the code comes back. If the code comes back then the control is the problem. If the code does not come back, then replace the key panel.
F2 – This means there has been a problem with the temperature of your oven. It could be a cooling fan or air flow problem. Also could be that the oven got too hot in either a baking mode or a cleaning mode.
-check to make sure the contactor contacts are not welded together. If this happens the oven will always be putting out heat, even if turn off. The thermal switch may also have burnt out. If this switch is open then the fan may be bad, causing the thermal switch to activate. The thermistor that senses oven temperature may also bed bad or have a poor connection somewhere.
F3 and F4 - These are oven temperature sensor codes.
- check the sensor by removing power to the range and then removing the sensor. Check that the sensor reads approximately 1100 Ohms at 72 degrees F. Then check the oven sensor lead to make sure that it is not shorted out. Then check the terminals to make sure that you are getting good contact. If everything checks out okay, then replace the control.
F5 – This is a relay safety circuit failure code
-check the lock circuit for problems. Then check the thermistor for high resistance. Press clear/off on the key pad and reprogram the control. If the code is still there then replace the control.
The F5 code can also result from a short loss of power. If you had a power flicker then reset the control.
FC – This shows a problem with the door lock circuit. Check all the wires and the switches. Check the operation of all the switches.
FD – This is a problem with the meat probe. Check the probe wiring and the receptacle where the probe plugs in at. Resistance on the probe should be 30 to 50K ohms at 72 degrees F.
FF – This is a problem with the door motor safety circuit. To fix this the control will need to be replaced.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Jul 01, 2010 | Ovens
My stainless frigidaire professional series electric stove oven door is locked...i did not self clean it, but it is locked somehow...if i hold either the lock button, or the clear/off button for 15 seconds...
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
Mar 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Wolf built-in Wall Oven 762. Convection Fans stop turning intermitantly Oven shut down with F1 warning Later restarted ? meaning of F1 warning
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
http://www.applianceaid.com/fault_codes.html
click the link
Dec 06, 2008 | Kitchen Ranges
PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Oct 19, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
"F1" DISPLAYED AND BEEPING
hi there,
the F1 code usually means that you have a key stuck on the keypad. unplugging it from power won't make a difference for this one. is it a wall oven or a stove? can you supply the make & model please?
Oct 03, 2008 | Ovens
Kenmore Elite Gas Stove
Will have to ask some basic questions first.  How old is the stove?  What is the entire model # from the sticker on the unit?  Is this LP or natural gas?  Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean).  Make sure that the black caps are on top of the burners and seated properly or they will not lite.  Let me know what you find.
Oct 16, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
104 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
