Question about Corona Miniature The Tennyson Dollhouse by Greenleaf sold at Miniatures
Greenleaf Dollhouse kit Tennyson
No instructions to put the house together
IS THERE A VIDEO HOW TO PUT TOGETHER A KIDSKRAFT SUPER MODEL DOLL HOUSE?
Hi
I didnt manage to find a video for the assembly but I did find a fairly decent image that may help as well as a detailed assembly (although you may already have this) sheet. You could try contacting Kidcraft as they do have assembly videos for their other dollhouse models.
Links Follow, trust this helps, best regards Alan.
Image ---> https://s-media-cache-ak0.pinimg.com/originals/fe/83/d9/fe83d925edb56790435f588120d13247.jpg
Instructions ----> http://www.kidkraft.com/_media/assembly-instructions/65827_intl_revised_copy5.pdf
Kidcraft contact page ---> Customer Service
Feb 13, 2015 | Toys
Need instructions in how to put oak breadboard breadbox together
Go to a wood working magazine, THIS OLD HOUSE; THE HANDYMAN, etc are 2 examples where they have step by step instructions
Jan 24, 2014 | Baby Gear
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
Replace a headlight bulb
When you open the hood opened, looking at the headlight housing, there are two bolts at the top of the housing that has to be removed. For this you need to access and remove the black plastic cover to access both of them. When the bolts are removed, lift from the top and it should pull out. You will need to turn the bulb retaining ring to free the bulb from the housing.By reverse the above said instructions you can put it all back together.
Thank you !!
Jul 05, 2010 | 2001 Pontiac Sunfire
Need the instruction manual for the 1980s Barbie Dream House
You can find a copy of the instructions on ebay for $5. Otherwise, its not impossible to figure it out without them. There are also spare parts on ebay, or you can buy a second house, make one complete one and sell one off for parts.
Apr 09, 2009 | Toys
I have a Nintendo DS Lite that needs a new housing. It works fine, just the rounded hinge on the right is bent and cracked because it was dropped. Can a local repair shop put a new housing on, or do I...
Go to this page on Nintendo's website. Regardless of your warranty status, they will offer repair options.
"Nintendo DS Lite - Plastic Housing and Hinge Issues
If your Nintendo DS is experiencing issues with the plastic housing (such as a cracked hinge), please contact our Consumer Service Department at 1-800-255-3700 so that we may provide you with repair options."
Nov 30, 2008 | Nintendo Computers & Internet
Corona Miniature The Tennyson Dollhouse by Greenleaf sold at Miniatures Logo
19 people viewed this question
Top Corona Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Corona Toy Expert? Answer questions, earn points and help others
