Question about Compaq Computers & Internet
Hard drive issue
Hi there I got a cpl of 40gb hard drives out of older computers dell, compaq etc when I plugged them into a working computer they were coming up as active partition not found, so I did a dariks boot and nook to completely wipe them, do I need to do anything else to them to install win 7 on or should they now be good to go ..
    Scholar:
  • 53 Answers
Hi Ricardo,
I am not familiar with Dariks Boot, but I am assuming that you formated them. That being the case, you should be able to install an operating system on them without any problems... as far as Win7 goes, it should work, but 40 GB is awful small for most current systems, especially windows needs room to move data around while it is running... if it does not have enough "breathing room" it will be slow.
Hope that helps
Posted on May 16, 2014
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: cannot boot from cd rom on compaq evo d310v, i have lost all disks but have the product key if it makes a difference. So what i wanted to do was wipe the hard drive with dariks boot and nook then inst
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Posted on Apr 21, 2013
Dell laptop HD
This model laptop came with a 60Gb hard drive and it will work with a 40Gb hard drive.
If it was me I would install a 60 Gb hard drive not a smaller one.
Apr 30, 2013 | Dell Inspiron Computers & Internet
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
Can I put in my PC Compaq Presario SR 1610NX a Hard drive Maxtor 40GB, 3.5 ? Thanks
Desktop Specs Link Motherboard Specs Link
A. From the first link above, you already have a 80GB 7200rpm hard drive and a combo drive with no further details. you can only use two additional devices one 3.5 inch external and 5.25 inch external bays.
B. Assuming that two devices are already IDE devices, that will leave you two additional IDE and two SATA device.
1. Turn off your computer before plugging any additional device and proceed with cautuion.
2. Add the additional 40GB Maxtor IDE hard drive, you will have to mount the drive into the casing and put some screw to lock or use tool lesslock if its present. (Check the jumper if its a master or slave) if you have configured the 40GB drive as master and you're going to add additional IDE drive you have to put the jumper in slave header.
3. Now put the IDE cable to the hard drive and to the IDE2 of the mother board mount firmly. (you cannot mount the IDE cable if it is in the wrong position)
4. Next the four pin power from the power supply to the hard drive. (you cannot mount the power cable if it is in the wrong position)
5. Power On your computer and press Delete or F2 to access bios, proceed to the option boot priority select your Combo drive as first boot, next your 80GB Hard driver, press F10 save.
6. Power On your computer and check your 40GB hard drive through device manager.
7. Time to add your new hard drive through disk management, so you will be able to see your new drive from your computer. I forgot how WIN XP recognize new hard drives especially the fresh one.
Hopefully this information helps.
Feel free to ask, so I can clarify things.
Thank you for using FixYa.
Sep 05, 2011 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
Iomega 320 external hard drive computer wont recognise
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
Replace existing 40GB internal HDD in laptop with 160GB internal
Drag and drop the files from one drive to the other.
  1. Plug your new drive in
  2. Right click 'my computer'
  3. than open 'C drive'
  4. repeat steps one and two
  5. than drag the files from C' drive to new drive'
Jan 05, 2009 | Computers & Internet
Error loading operating system
If you take a hard drive for one computer to another the windows wil have to be reinstalled as windows looks at the hardware configuation and if it doesn not match, will not run. If the 20 gb hard is working , reinstall it then using backup software back it up to another hard drive.That will work. Personally I use" Acronis true home" software to change a hard drive but their  are other  wil also work. Some  backup and transfer softwware even come with the replacment hard drives.
Dec 10, 2008 | Compaq Presario 5000 PC Desktop
No operating system no os setup disk the bois is compaq verion686s4 relase date 25/07/2000 this computer is winwows 98 with a amd-k6-2 at 550MHz processor and a 15 gb hard drive [ i have a windows 98 40gb...
no sir,,u have reinstall the windows 98 in the swapped hard drive coz only when they gets installed registeries r set,,once u install the windows 98 continue installing the system driver n everyhting will be functioning fantastic
Jul 05, 2008 | Compaq Computers & Internet
Computers & Internet Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
