Question about iCandy Peach Stroller
Handle bar cable
Cable has snapped inside handle so can't extend or collapse
The same has just happened to mine, I've tried to contact icandy but no success !! Have you managed to fix yours yet?
Posted on Jun 24, 2013
  • Ashleigh Dillon Aug 18, 2013
    Have you guys managed to get it fixed? Mine has also snapped no one side x
My cable snapped on my parking brake....
snapped cable released brake, handle is stuck behind panel
May 24, 2013 | 2000 Chrysler Grand Voyager
Quinny buzz 4 push handle release mechanism for extending handle - the steel wires have worn and snapped - How do you dismantle the push bar and where can you get the steel cables with the barrels on the...
Hi - The cable from inside the Buzz handlebar is not available as a seperate spare part item. To obtain a replacement you need to replace the handlebar, which comes with all the required inner workings. If your Buzz is under 2 years old please contact your retailer with your proof of purchase to make a warranty claim. If it is over 2 years old or you do not have proof of purchase you should contact your customer services department. If you're in the UK please call 01284 413 141 Mon-Fri 8.30-4.30.
Oct 05, 2011 | Quinny Buzz 4 Storm Stroller
I have a Huffy Verona 18 speed with the Soleus shifter first the cable wasn't working so I put wd-40 down the cable that has freed it up but I'm having problems getting the rear railer to change...
When I have had that trouble with my own bike, I have taken the cable off and replaced the vinyl housing. If that isn't an option, get the cable as free as you can, then lubricate the rear derailer, and with a cloth, so as not to soil your hands, grab hold of the derailer and work it back and forth to free it up. Riding the bike causes all the road grime to accumulate on the derailer making it stick.
Hope this is of some help
Joe
Aug 30, 2011 | Cycling
Adjustable handle bar is broke think cable inside has snapped
hi this is replaceable but you have to replace the handle and not just the cable easy to do look at
this video for the mothercare my3/4 (same handle as quinny)
http://www.youtube.com/watch?v=viSDFutpAOY
parts are available direct from quinny
please let me know your country and i will post contact details for them
Feb 19, 2011 | Quinny Buzz Three Wheel Stroller
Install door latch cable
Technical Instructions
See picture below
1. Remove door trim panel and water shield per
NOTE: Place a strip of masking tape along the edge of door before removing trim panel to prevent scratching the door with the trim panel removal tool.
2. Snap cable housing end from slot on inside door handle assembly and disconnect cable.
NOTE: Use care to prevent bending of cable housing retainer bracket.
3. Remove rear window channel retaining bolt to allow access to door latch.
4. Position a block (screwdriver handle) between the latch and the door inner panel and snap the cable housing end out of slot (towards inner panel) on door latch assembly and disconnect cable at latch.
NOTE: Use care when removing cable housing to avoid bending of the latch. Discard cable.
5. Hook up new cable at latch and snap cable housing end into slot.
NOTE: Make sure the cable housing is fully seated in the slot.
6. Apply a light film of Teflon grease to the barrel end of the cable. See Figure A.
7. Install return spring. See Figure A.
NOTE: Ensure that the push button rod is located between the spring and the door inner panel.
8. Install foam block at latch. See Figure A.
9. Position water shield over the return spring and install push pin to retain upper portion of water shield. See Figure B.
NOTE: Push pin goes in the same hole as the return spring.
10. Clean hands of grease before performing step 11.
11. Remove protective backing along the lower edges only of the water shield. See Figure A.
12. Install latch water shield at door latch. Pinch the exposed adhesive surfaces together to secure the water shield. Check to insure water shield is not showing through the door shut-face latch access hole. See Figure B.
13. Attach cable to inside door handle assembly and snap cable housing into slot.
NOTE: Make sure the cable housing is fully seated.
14. Check the gap as shown in remote control using a 3/16 drill bit shank end. The drill bit shank should fit in the gap without any clearance and a tight fit is preferred. See Figure C.
15. If the drill bit is too loose or does not fit, adjust by bending the cable bracket as required.
16. Place plastic wedge on remote bracket as shown. Wedge must fit with at least a light press fit for retention. See Figure D.
17. After installation, Apply a dab of special Teflon grease, supplied with the service cable to cable housing openings at inside handle end. The grease should surround and contact the cable all the way around, to seal the opening between the cable and the cable housing.
18. Check all latch functions to insure correct assembly of latch system. If the inside handle does not release properly, replace the inside handle remote release mechanism.
19. Reposition and install trim panel using new push pins if required.
Dec 07, 2010 | 1993 Ford F250
The handlebar adjustment cable in our quinny buzz has snapped - can you buy (and install) a replacement cable
hi you have to get the handle bar assembly and they are easy to change
here is a video of how to change one for the mothercare my3/4 but its the same as the buzz
http://www.youtube.com/user/dorelengineers#p/a/u/1/viSDFutpAOY
which country are you in and i will try to get you a link to the handle part
Nov 01, 2010 | Quinny Buzz Three Wheel Stroller
Shimano gears for a cycle... gear selecter not working at the r/handle bar end. I've dismantled it and trying to work out how the wire works and is set back in place as it is a twistgrip type.....
Check the rear dérailleur and the wire which protrudes. Its sounds like it has come loose and slipped, causing you not to get any gears. Follow the wire from the r/h twist grip, along the frame and towards the rear. If the wire has come out of its stoppers then refit.
If the wire is snapped inside, you should be able to see the cable move when you change gear. When you can't see the cable move, it will be snapped inside there. Are the exposed wires rusty? High possibility of a snapped wire.
I hope this helps, please vote for me if it does. Thanks.
Jun 17, 2010 | Cycling
Well my hood is jammed shut cable seems to have snapped
if you pried the hood up enough to see the latch then you should be able to reach the cable with a pair of pliers or vise grips, or you could see if you can reach the bolts holding the hood latch and remove it.
you may want to check where the cable attaches to the handle inside the vehicle and see if it is still connected.perhaps the release handle is broken and you might be able to pull the release cable with pliers.
good luck and I hope this helps.
Mar 31, 2010 | 2001 Chrysler LHS
The hood release on my 1993 chevy lumina snapped. the lever seems to have snapped from inside the car since it isnt attatced anymore. how much will this cost to fix at a shop?
YOU CAN FIX IT EASILY AT HOME IF IT IS JUST THE HANDLE. THE CABLE WOULD REQUIRE ABOUT 1-1.5 HOURS LABOR TO REPLACE SO DONT PAY MORE THAN THAT.
May 19, 2009 | 1993 Chevrolet Lumina
iCandy Peach Stroller Logo
286 people viewed this question
Top iCandy Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you an iCandy Baby Gear Expert? Answer questions, earn points and help others
