Question about Ricoh Aficio 250 Copier
Code sc 21 01 konica - Ricoh Aficio 250 Copier
I have a error in konica 7055,code F-56
Enter in the service mode,select SC code history and read the code description.
Jan 17, 2013 | Konica Minolta Office Equipment & Supplies
Photo copier solution
Enter in the service mode:press
Utility key - meter count - details - Stop 0 0 Stop 0 1
or in sistems or in counter mode select "service call condition" or sc service call and you look the sc codes tables.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
Error code sc 49-04 for konica 1050 copier
Aug 27, 2012 | Office Equipment & Supplies
I have a konica 7075 and the service report code is SC23-01
Sir, check the toner bottle! SC-23-01, is a toner bottle motor issue
Aug 18, 2009 | Konica Minolta Office Equipment & Supplies
Ricoh Aficio 250 Copier Logo
107 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
