Question about Whirlpool Washing Machines
AWO D 8712
F23 FAULT CODE
4 Suggested Answers
  • 1550 Answers
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
SOURCE: Whirlpool AWO/D 7740 error code F23
error code f23
Posted on Oct 17, 2010
jyackle5
  • 8197 Answers
SOURCE: I have a whirlpool washing
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
Posted on Nov 28, 2010
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
My brand new Whirlpool AWO/D 7740 shows error code f23 5 seconds after starting any program and won't do anything.
don't touch it
as it is still under warranty , call in a service technician for a warranty repair
Jan 28, 2016 | Whirlpool Washing Machines
How do I fix error code F23 on Kenmore oven
Googled error code F32 Kenmore oven and got this: Sears Parts Direct.com. Quote: "The F23 error indicates a communication fault between the main electronic control and the variable speed convection board.
Most likely the variable speed control board will have to be replaced.
I recommend a technician check and repair this problem." Hope this is your oven. You can also download an installation guide and owners manual here.
Dec 10, 2014 | Kenmore Kitchen Ranges
I am having a problem with my Whirlpool AWO/D 43135 washing machine.It stops when starting any program and shows error code F23.What should I do?
The fault F23 could be linked to the water temperature not reaching the right temperature. If your model uses hot water inlet connection then check if your hot water unit is providing the correct inlet water temperature. Otherwise it is likely the temperature sensor or heater element maybe failing.
See description
HEATER FAILURE
If the temperature increase during the first 40 minutes is less than 86degF (30degC).
1. Unplug washer or disconnect power.
2. Check connection to water heater.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
Jul 31, 2014 | Whirlpool Washing Machines
We have an Gaggenau eb 290 oven and the error code F23 shows up - what does this mean? how can we fix it?
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
May 13, 2010 | Gaggenau EB290 Electric Single Oven
Code f23 for whirlpool washing machine
Hope this helps.
jenni.
Sep 09, 2009 | Washing Machines
The error F23
Try this
Hope this helps .
Feb 21, 2009 | Whirlpool Washing Machines
I just purchased a Duet Dryer, model #WED9400SW...When I try to dry clothes, after approx. 1 min., I get fault code F23...Can you help???
contact whirlpool factory service for help the number is in the owners manual, the f23 does not show up in my tech sheets, it is under warranty
Apr 12, 2008 | Dryers
Washing Machines Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal De
