Question about Fuji FinePix S7000 Digital Camera
My finepix S7000 is misbehaving
The camera has SUDDENLY informed me that 'card not intiialized'. Tried to format media but its not permitting this, cleaned the contact area on the SD card... What else can I do?
    Genius:
  • 2,985 Answers
Have you/can you try another card or try the card in another Fuji camera to establish where the fault lays - Camera or Card? Also contact customer support at Fuji.
Posted on Aug 06, 2007
6ya staff
SOURCE:
Formatting an CF 4GB sandisk ultra II....How to do
The camera uses FAT16 so it won't be able to use cards bigger than 2GB. IF you can format it, you will only have 2GB space available.
Formatting the card: Press Menu/OK, select Setup, Select Format, press OK untill it's done.
Oct 11, 2009 | Fuji FinePix S7000 Digital Camera
Camera says card not intialized, but I formatted the memory card
Format it using the camera instead of using your computer.
Sep 22, 2009 | Fuji FinePix S7000 Digital Camera
Finepix s7000 new 4gb card not initialized fujifilm cf
The S700 as it came from the factory CANNOT use a 4 gig card. You must go to the Fuji USA website and download the firmware update. You will need to have the program that came with the camera installed, and the cable that also came with the camera. Make sure that you have fresh batteries in the camera. Instructions are on the Fuji website along with the download for the firmware. You are actually going to "flash" the firmware in the camera just as if you were doing a BIOS flash in your computer. Personally, I only use smaller cards and remove the pics soon after I take them. A 2 gig card will hold about 150 full rez pics. Get them out of the camera....don't save them forever on the card!
Jun 12, 2009 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera ''CARD ERROR''
Hi there
Try using the format options in the camera's menu.
Hope this works for you.
Thanks for using Fixya!!
Feb 06, 2009 | Fuji FinePix S7000 Digital Camera
Fuji finepix s7000
Per the owner's manual:
  1. Insert a formatted media into the camera.
  2. Set "RENEW" as the FRAME NO. setting in the SET-UP menu.
  3. Start taking pictures. (the frame numbers start from "100-0001".)
  4. Set "CONT." as the FRAME NO. setting in the SET-UP menu.
Then you're done. We just did this on ours and now we're ready to go. God Bless.
Jun 05, 2008 | Fuji FinePix S7000 Digital Camera
Got a card intializing msg!!!
The S7000 has always been known to have some problems with regular CompactFlash cards, with both power drains and limitations reported (the S7000 seems unable to handle CompactFlash cards above 2GB, as it doesn't support FAT32). I imagine it's possible that there are other potential problems associated with this.
It's usually recommended that, instead of using CompactFlash cards, you use either xD-Picture Cards or IBM/Hitachi Microdrives, which are both fully compatible with the S7000.
May 11, 2008 | Fuji FinePix S7000 Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix A330
Go here for the manual in PDF format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Dec 17, 2007 | Fuji FinePix S7000 Digital Camera
The batteries were drained in my FinePix S7000 camera whthe camera was not in use.
The CompactFlash card may have caused the batteries to drain. Some solid state CompactFlash cards consume power while inserted in the FinePix S7000 even if the camera is turned OFF. Fujifilm recommends removing the CompactFlash card when the camera is not in use. Microdrives and xD-Picture Cards do not exhibit this problem.
Aug 29, 2005 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
66 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
