Question about Delta Machinery 1/2 Hp Hollow - Chisel Mortiser
Motor falls without pulling it down - Delta Machinery 1/2 Hp Hollow - Chisel Mortiser
    Top Expert:
  • 42,218 Answers
Check for broken spring that holds it up.
Posted on May 18, 2013
Ms330
A little more info is needed.
Compression test: a simple way is to hold the pull cord like you are going to start the saw. A strong motor with good compression tends to either stay in place or slowly fall as the piston moves. If the saw just falls down the motor is worn.
But compression increases as a motor warms up so I don't think this is your problem. If it was the saw would be very difficult to start like my dad's old Stihl 041 Farm Boss from the early 1970s.
20 minutes is a long time to run without a problem.
Consider cleaning the carburetor (or a small can of goof off) with carb cleaner - but don't get it on plastic or rubber parts only metal.
Smoke: How much smoke is there? If there is no smoke the mixture might not have enough oil causing the motor to overheat. Also, many small engines recommend regular not premium gas.
Apr 24, 2014 | Stihl Garden
Why don't birds fall off their perches while they sleep?
Birds have tendons on their feet, called flexor tendons, which respond well to pressure. This allows them to sleep comfortably on a perch without the worry of falling off. These tendons run down the back of a birds leg all the way to the tips of their toes. As the bird lands on a perch, the tendons pull on the toes and close them tightly.
Aug 30, 2012 | Allied Precision Birds
There is water flowing to the dishwasher, but it is not filling with water. I hae checked the filter but dont know what to do next. The motor is running, it is just dry inside.
The motor you can hear is the pump motor. This means the machine is trying to pump out so it's likely the flood protection has been activated.
Open the washer door, pull the lower basket out and locate the float - It's the grey plastic dome just behind and between the salt compartment cap and the drain/filter.
See if you can push it down. If you can push it down and it rises back up it means you have water leaking into the bottom of the washer beneath the washing compartment.
If you can push it down and it stays down. you should be able to use the washer, but I recommend cleaning under the dome and making sure it rises and falls without sticking before you do.
Oct 02, 2010 | Bosch 24 in. SGS43C12 Classixx...
Power window not working can hear motor turning also window is falling down
pull the side panel off the door. Gears in the slide on the motor may be offsheared. Or hold button down on window and tap the motor
Apr 05, 2010 | 1994 Lincoln Town Car
Pulled the pin bolt instead of drain plug
Sorry. I'm very certain you can't fix your problem without splitting the case. I would be cautious about running the motor at all. When you removed that bolt those pieces are free to fall down to the bottom of the case to interfere and do damage. Good Luck.
Jan 23, 2010 | 1985 Honda XR 250 R
97 town car trunk pull down stopped working ???
i pulled entire lower assembly off, removed motor casing and found that the plastic ring gear that pulls the truck down was stripped. I then pulled the whole thing apart using simple tools and turned the ring gear by hand to about 3/8 inch above the full down position. I then reassembled and re-installed without the switch and without the motor. Trunk closes like a normal trunk now (no pull down obviously. I am not a mechanic and it only took about an hour and two beers, no money. 93 lincoln town car.
Note: you will need torx bits but that is the only thing "specialized" in the operation
Oct 19, 2009 | 1997 Lincoln Continental
Electric motor ok window will not up or down makes noise like window is sliping can pull it up falls back down 1990 dodge caravan
Sounds like it came off the track, so the motor will still move the track up and down but not the window.
Aug 16, 2009 | 1990 Dodge Caravan
Have a 2000 Alero. drivers window won't stay up, falls down.
The Regulator is not okay, replace it, it is bad.
Feb 28, 2009 | 2000 Oldsmobile Alero
Replacing 99 Accord window regulator
Pull off door panel speaker and switches. lower the window to where you see the two or four 10millimeter that connect scissor mechanism to the window. Prop window all the way up and put a door stopper to prevent the window from falling down. Unbolt window motor, unplug window motor, and unbolt eveything else in the door. Pull it all down and out through the bottom largest whole, lay flat on ground the entire indoor mechanism, out where you can see it on the floor. Take a pic with camera, and proceed to swapping regulator, intallation is same as removal. Good Luck
Dec 28, 2008 | 2000 Honda Accord
Side door window fall down is power windows when i try to pull window down i can hear that window about to go down and that, some times window do go down but when i try to pull up window no problem
If your windows are power you need to replace the window regulator.They are aroud a $100.00 dollars but it comes complete with motor.There are no servicable small parts for them,you have to buy complete.
Aug 08, 2008 | 2000 Pontiac Grand Am GT
Delta Machinery 1/2 Hp Hollow - Chisel Mortiser Logo
63 people viewed this question
Top Delta Machinery Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Delta Machinery Craft and Hobby Expert? Answer questions, earn points and help others
