Question about Dell Computers & Internet
Suddenly i can't open my photos. all i get is a box with a red x in the corner
  • 5,245 Answers
Before trying to open the photo, right click on icon.
Select 'open with'
Small box opens with choices.
Select 'windows photo viewer' or whichever program commonly used on your device.
Another typical solution can include restarting computer...
Another solution can be system restore. With windows 7, go to start button, search bar appears at bottom, search for system restore, system restore appears at top, click on system restore and follow steps to restore computer to previous date when computer was functioning correctly.
Posted on Apr 27, 2013
GEARS NOT SHIFTING PROPERLY
This is one flaw of MANY manufacturer's boo boos that I dealt with, and I am less than pleased given the price I paid for this Novalis flooring. They will be receiving a letter, as I have already written the major box store, Lowes.
I was excited when I opened the boxes, already had my chalk lines down, assistance with me, and began laying the tiles out in the correct direction. My mother, my assistance, began peeling the backs, and lying the tile into the lines. The first half of the box went smoothly, until it didn't. The tiles began to vary in size & shape, my mother mentioned it in a concerned tone. I looked through the rest of that box to find broken corners & more variance of sizes and shapes. Given I live an hour from Lowes, I called to ask if they had any more of the tiles I had, they did not have any, nor could they get any.
Being we were in the midst of the install coupled with being an uncontrolled Epileptic who cannot drive meant we were stuck with what we had. So, we decided to go ahead and open the other seven boxes of tile to see if it were just a fluke; it was NOT a fluke. So, we picked and chose the best tiles possible from the seven boxes. We then installed those tiles in the center of the room, leaving the jacked up tiles for cuts and along the walls where they would hopefully draw less attention. Sadly, we did NOT have enough tiles to complete the center of the room, given there were THAT many tiles with foibles which were not able to be ignored. We finished the install, while we managed the installation process without issue, the tiles are ANYTHING but up to par.
There are so very many problems with this entire ordeal in installing these tiles. I don't like the fact that I bought this with my "nest egg" money, I scrimped & saved specifically for this remodel. Only to open the tiles I paid so much to purchase, to find they were absolutely screw-balled with foibles. The tiles were NOT square aka misshapen & mis-measured tiles, beneath the paper debris was stuck to the glue on the back of the tiles, broken edges that were still inside the unopened boxes that were heavily padded, and some tiles were even glued to one another, when carefully separated you learned that one was broken. How this tile in the attached photo ended up getting wood embedded in it's front, I have no idea?
I am UNHAPPY. I would rather have purchased American, paid more for them, and cut corners somewhere else in my remodel insuring my floor looked perfect! We worked too hard to have it turn out as it did. Live & Learn!
Jul 10, 2012 | 1998 Ford Windstar
Create email
go to gmail
in the upper right hand corner there's should be the words NEW TO GMAIL & there will be a red box that says CREATE AN ACCOUNT--
just click on it & follow the prompts
Jan 21, 2012 | Google Gmail
Changing the air filter
How to change the air filter on a 2006 VW Jetta 2.0 FSI:
1. Unplug the Mass Air Flow (MAF) sensor.
2. Undo the spring clips and pull out the turbo inlet connector.
3. Remove the two T-25 screws on the air snorkle as shown below.
4. Remove the engine cover by pulling up HARD where indicated by the green circles in the photo below.
5. DO NOT APPLY ANY FORCE where indicated by the red diamonds in the photo below.
6. If it's cold weather, make sure the engine is warm so that the rubber grommets warm up and are flexible enough to come off. Cold, brittle plastic and stiff grommets will lead to a broken airbox/cover even if you otherwise do everything correctly.
7. Pull up on the rear driver's corner (near the battery box) first, then the rear corner where the MAF sensor is, then the fronts.
Jun 01, 2011 | 2006 Volkswagen Jetta
Can not find the release for my air filter 2007 2 liter EOS
5. DO NOT APPLY ANY FORCE where indicated by the red diamonds in the photo below. 6. If it's cold weather, make sure the engine is warm so that the rubber grommets warm up and are flexible enough to come off. Cold, brittle plastic and stiff grommets will lead to a broken airbox/cover even if you otherwise do everything correctly.
Apr 29, 2011 | Volkswagen Eos Cars & Trucks
Hi, My cars central locking (C220 model) has stopped working all of a sudden. The doors will not lock/unlcok using the key & i am using the key (metal) bit to open and close the doors manually. When...
Replace Fuse 27 in main fuse box located under the hood black box in far right corner. Then try reseting your battery. Make sure to follow these steps as follow. Unhook the - then + of the battery. Clean both the negative and postive of the battery. Next go under the hood far right and replace Fuse 27 which is 15 type fuse green in color. Wait 20 minutes for reset of the computer then attach the + and - cables back to the battery.
Sep 16, 2010 | Mercedes-Benz C-Class Cars & Trucks
I am unable to open photos e-mailed to me from a cell phone. There is a red x in the upper left hand corner space for the photo but I can't get it to show picture. This also happens will e-mails with...
Check your Yahoo mail settings to make sure you don't have a box checked that prohibits you from viewing photos in an email, or attached to an email.
Also, try right clicking, if it's an attachment, and look at your options. You might have to save it as a different type of file before viewing.
I know sometimes, the photo file type that a cell phone takes may be incompatible with common programs that a computer has to open it.
Apr 01, 2010 | Yahoo Mail
Red X and Blank IE window
CHECK THE INTERNET CONNECTION AND MAKE SURE THAT YOUR CONNECTED. OPEN INTERNT EXPLORE AND GOTO:
TOOLS
INTERNET OPTIONS
CONNECTIONS
LAN SETTINGS
MAKE SURE THAT THE AUTOMATICALLY DETECT SETTINGS BOX IS CHECKED AND CLICK OK......
HOPE THIS HELPS
May 04, 2009 | Sony VAIO VGC-RB42G PC Desktop
Panasonic Lumix Digital Camera - Marks on Photos
Is the marks on the photo after download, or just on camera display.
If just on display, would suspect display failure. If not, corner problem could be lens cover is not opening completely (a common problem with this model) or dirty lens itself.
May 16, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
