What can you connect skytronic 100.070 speakers too
What can you connect skytronic speakers too
2 Suggested Answers
  • 5603 Answers
SOURCE: How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Posted on Dec 28, 2009
Instruction manual
https://www.manualslib.com/manual/847982/Skytronic-600-005.html
Aug 23, 2014 | Measuring Tools & Sensors
Skytronic inverter 300W 12V
check for an overload button / reset switch
could be less inefficient now than when new and if the total wattage of the bulbs exceeds 280 watts then it may be burnt out
Jun 25, 2017 | Televison & Video
Fault Light/ inverter failure
the current from the 12volt supply is not sufficient try a fully charged car battery instead, your inverter needs 30 amps and above of current from 12 volt power supply
Jul 20, 2013 | Televison & Video
My skytronic power invertor is making a constant beeping noise
do you have a load plug in at the time if so try it with nothing plugged in if all is fine the load may be to big for the invertor
Apr 04, 2010 | Electronics - Others
Dec 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Hi, i've got a skytronic 300w soft start inverter making loud beep and then cutting out. I know its one of the safety cut outs but not which one. can it be repaired ? thanks
If your appliance draws over 300W or if your 12 v battery charge is low you will get a loud beep warning. Do you get the same beep with a low current appliance like a lamp? Make sure your battery has a good charge.
Some appliances have huge draw at start up even though they are rated under 300w your inverter may not be able to start.
Also some electric motors don't like modified sign wave inverters.
What are you trying to run and what is its rated watts?
I had my inverter beep when I had it connected via a cigarette lighter plug but when I used a connection straight to the battery it worked fine.
I was running a 500w grinder on a 1000w el cheepo inverter.
Aug 17, 2009 | Electronics - Others
62 people viewed this question
 Grubhead
Grubhead
