Question about Candy 17 in. CS455 Built-in Dishwasher
Candy Dishwasher CS455M
When I switch my dishwasher on the motor hums but it does not take in any water. I tried putting water in with the door open but it drained the water out and did not wash.
  • Anonymous Feb 06, 2008
    I rectified my own problem - I put a lot of water straight in shut the door and it worked. With the 3 in 1 tablets I now cut them in two and use half - this seems to work. The programme I use is 2 o'clock and I have no problems even if I only switch it on every 3 or 4 days.
  • Anonymous Aug 03, 2008
    My dishwasher motor is humming when i close the door and no water is being taken into the drum, also the lights are flashing on the 65 and 70 cycle, can anyone help
I have just bought a candy dishwasher cs455 and have no manual can you tell me the best wash and what to set it on thanks
Posted on Feb 05, 2008
Hobart dishwasher wont fill and motor hums
Hi SubaruB4
it may be the electric valve where the water comes in if it doesn't open when switched on water wont enter
Dec 26, 2017 | Hobart Dishwashers
Dishwasher fills with water. then hums but dosen't clean
Sounds like water-level sensor is ok as it stops filling then 'hums'. I'd (carefully) check the connections to the connections between the level-sensor and the wash motor start relay. Could be motor is bad or something is causing it to become 'jammed'. Before you begin opening the appliance, I'd attempt to vacuum out the water or try putting the control in the last position to cause it to try to pump out the water.
Mar 01, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
I have a Candy dishwasher. Door is open switch on sounds like something (possibly pump) is running and error E4 shown on diaplay. Any ideas please?
Overflow tray (bottom dishwasher). Tilt your dishwasher, pour water and see the reason for the overflow. I blew off the top hose from the pump.
Jul 20, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Candy Dfi 85s intergrated dishwasher
candy dishwasher wont turn on , lights are out , it is plugged in any ideas please ?
Mar 02, 2009 | Candy DFI Plan Built-In Dishwasher
Candy nova cd112 dishwasher fills with water then stops working
nova cd112 this is a simple fix the machine has a electronic switch to add water to the machine it then has another switch to say the machine has water iin it , this switch is the one that is not working this is the one that turns on the element and heat the water .it costs around a tenner to replace u can find it as it is connected to the element via a wire conection .this a a common problem of over enginearing as this switch is not needed and is not on older machine .ie this switch can only come on when the machine has water in it in other words only after the switch to put water in the machine has been on.can this go on i hope u know what i mean lol. now u can replace this yourself or get an engineer it should take an engineer no more than 10/15 mins to fix better still have him bypass this switch and u will never haver the problem again as this switch is prone to going fixthis and the machine should last years no problem as its not a bad machine not quite a bosch but better than a zanussi or indicit etc hope this helps and may i just say that i tried everything including replacing the element ,stat and cpu non of which worked before realizing it was this .i must also say before u try this. Switch on your machine on put it on a universal cycle as u hear the water going in the machine open the door and add hot water as hot as u can close the door and the machine should do a full cycle including emptying and reheating the water this proves its not the cpu ,element or stat note the machine will not do the cycle without the hot water going in at the start if it does the cycle then its 100 % this switch hope this helps and sorry for the lond explantion bye
Feb 20, 2009 | Candy 24 in. CD622 Free-standing...
The Condensor connected at the power supply point of my Candy Dis
Their is not condensor on a dish-washer?
Do you hear a humming noise? Do you mean your motor? Have your tried rotating the motor fan blades to unjam the motor?
Jan 26, 2009 | Candy 24 in. CD623 Free-standing...
Hello penny123
Welcome to fixya.
My name is Huuum at your service.
I found the site where you can read or download your proper User manual for the
Candy CS455M Dishwasher.
Below is the site that will take you directly to the Candy online Manual search.
When there, Manually start typing in the sc455 and a few model choices will pop up.Choose your cs455m and when it opens , you may print it or just read it to acquire the information you need.
Please Remember to leave a solved rating for me, before you leave our fixya site.
Thank You Huuum
Sep 30, 2008 | Candy 17 in. CS455 Built-in Dishwasher
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Candy 17 in. CS455 Built-in Dishwasher Logo
552 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
