What does ft mean on a delonghi ariadry slim des 16e
Hi I have a delongha aria dry slim des 16e and the display is coming up with a "ft" code. can you please let me know what this means and how to get the machine working. thanks
  • 183 Answers
SOURCE: Error message F04
FO4 indicates a pump fault.
Posted on Sep 01, 2007
SOURCE: frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Posted on Jul 13, 2008
geemarie
  • 876 Answers
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
  • 4 Answers
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Posted on Feb 18, 2009
SOURCE: LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
Posted on May 31, 2009
Why does my LG refrigerator LFD22860SW display a code of 22 22 and sometimes 33 33 what does it mean?
Here is a link to a 25 cu. ft. model Service Manual=>
LFD25860xx LG 25 ft French Door Refrigerator Service Manual.pdf You can also find other information on my website Appliance 911 If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 06, 2014 | Refrigerators
Sim network unlock pin
It means your phone is network locked. You can simply unlock it by your phone unique unlock code. Get it from http://www.fastgsm.com/en/htc/aria/unlock-code/network-unlock
Feb 08, 2014 | HTC Aria Cell Phone
I dont know how to reset my htc aria
Please note that all data will be deleted from the HTC Aria as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
  1. Turn the power off. If your HTC Aria is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Hold the Power button until the display turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button to select
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the HTC Aria. Once the wipe is complete, the phone will reboot to its factory fresh state.
Oct 19, 2011 | HTC Aria Cell Phone
I need to unlock my htc aria
To Unlock the HTC Aria Phone Reach here
Wickedunlock.com buy the Unlock code and Unlock it step by step.....
HTC Aria Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HTC Aria mobile phones. If you enter over a certain amount of wrong unlock codes on your HTC Aria mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Aria with a Not ACCEPTED SIM Card.
2. If your HTC Aria asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Aria will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Aria is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your HTC Aria is locked to.
May 24, 2011 | HTC Aria Cell Phone
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Check engine light on 1996 328i BMW, scanner codes P1421 & P1423
go to the link below, type in the code and the difinition of that code comes up in a list as defined by each car maker.
http://www.aboutautomobile.com/DTC/P1494
Jan 30, 2010 | 1997 BMW 328
Error e16 or 16e
It means that you don't have original ink cartriges and the printer can't determine the level of ink. Hold the ok button (the one in the lower right corner) until it overrides the error, and soon it will start printing, disregarding the level of ink.
Jun 01, 2009 | Canon Office Equipment & Supplies
D link DES 1048G Switch, is facing communication problem
u r saying after restarting of switch it is working fine.
  1. is ur switch is getting hit while it is hangup
  2. leds are starting blinking ??
if switch get hit u need to send it to service centre and replace card.
if switch is hanging while all LEDS are blinking this means one of the network calbe is getting short. u may need to search the faulty cable and restart the switch
May 09, 2009 | D-Link DES 1048G (DES-1048G) Networking...
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
