Question about Hayward Pool Products Hayward H250 250k BTU Millivolt Pool Heater - Propane
Hayward H250 pool heater will not light
I cleaned the burners, igniter, and flame sensor. The igniter does glow. The fan comes on. Gas flows. The burners will not light. After 3 tries, I get 1F code. Why won't it light?
    Top Expert:
  • Hayward Pool... Master
  • 8,514 Answers
See if pressure switch full voltage both sides or hi limits
Posted on Aug 30, 2017
3 Suggested Answers
  • 15 Answers
SOURCE: Hayward H Series 400,000 BTU Pool Heater Won't Ignite
You can not manually light it. Open the front cover look for the gas nozzles brass looking on a tube. on the right side you will see a wire going to a sensor above the next to last burner take the nozzle out for that burner. 7/16 wrench unsrcew the nozzle and see if it is clogged. use something soft to push it out. Spiders love to lay eggs in these. Spray with WD40 and reassemble should work now
Best of luck
Posted on Jun 23, 2009
jharwell668
  • 640 Answers
SOURCE: Pilot light on H Series Hayward pool heater wont
You might need to have your gas lines cleaned. If there is a blockage of the gas line, you might not be getting enough fuel to start the heater. If that doesn't solve the problem, try consulting the owners manual for these pool heaters. The troubleshooting guide might help you narrow down the problem.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
Hayward heater h150 ignites and shuts off
check pilot generator if 500 millivolts to gas valve turn on switch if lowers should light if not check wires could be loose make sure flame sensor is above burner if not it wont sense flame
Jul 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
How do you change the flame sensor
It is not a flame sensor. It is a pilot generator or sometimes it is called a thermal pile or thermocouple.
easy to replace...
loosen brass nut, with aluminum tube at gas valve, and take good notice here... Two wires follow along the tubing and are connected to two of three screws on top of gas valve - loosen and remove. then unsecure pilot assembly from under the burner tray. Pull out the pilot assembly as one unit along with the tubing.
Then either unscrew small retaining nut or just pull straight down and generator will slide out.
i would replace the whole pilot assembly. If not at least clean the pilot orifice!
look at the picture at the following site. Click on 'enlarge picture'
good luck.
Parts4heating com Teledyne Laars R0027600 Pool Heater Universal Pilot...
Jun 15, 2014 | Hayward H-series Electronic Gas Pool...
Hi I have an H400 hayward. when heater is activated, it stays on for 5 seconds then shuts down eventually reading ignition failure code or IF on screen. the ignitor is new, the heat sensor is new, the gas...
When you say it stays on, Does the main burner actually light? If the burner never lights, then I'd look closely at the igniter, as it also acts as the flame sensor. Possibly you have a good enough ground to get a spark, but not good enough to sense the flame. If the main flame is starting, look and see if it is blowing off of the igniter. If this is the case, perhaps it isn't in the correct position, or there are still a few dirty passageways in the main burner. You can download a manual for your heater here: http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
Aug 10, 2010 | Hayward H400 High Wind Stack
Haward H250 dual therm, heater lights then shuts off after 5 to 10 seconds,even with pressure switch bypassed
it sounds like a flame sensor.its located in lower end of burner box,remove it and clean with fine steel wool or emory cloth.
Sep 02, 2009 | Hayward Pool Products HAYWARD H-Series In...
H250 inground pool heater turns on 5 seconds shuts off flsahing 1f
This is a code for ignition falure. If you are getting a pilot then it means your Ignition module is not sensing the flame and shuting the gas down. This could be pilot wire burnt and grounding or a pilot flame not reaching the sensor or a bad ignition module. This is the expensive part so look into the other things first. Good luck.
Jun 26, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Jun 20, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Pilot light is lit, but heater will not fire
Make sure thermostat is set higher than water temperature. Make sure pump is running and water is flowing through unit. If gas valve is not opening then flame sensor or gas valve is bad.
Jun 02, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Heater won't stay lit
On your main gas manifold you have orfaces that screw into it at each burner. Remove these and see if their are small spider webs in them. They will look like little lint balls. They can keep your main burner from getting gas and in turn keep the heater from sensing flame. The pilot lights and the heater starts but no flame at the main will shut it rite down. See if this helps.
May 05, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward h250, wont heat
Sounds like it could be the flame sensor.
Apr 04, 2009 | Hayward H Series Electronic Ignition...
Hayward Pool Products Hayward H250 250k BTU Millivolt Pool Heater - Propane Logo
139 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
