Question about Measuring Tools & Sensors
UNI-T UT392A laser measure - Measuring Tools & Sensors
Need new battery, of course I removed the battery some time ago to go and replace it. Yup its lost.
you lost your battery - bring a unit with you and ask for battery that fits in the store.
Dec 11, 2013 | Starrett D125 Digitape 1Inch x 25...
I have a unibrow ie my eyebrows dont really separate in the middle. What can I do about it?
Tweezers are a good way of shaping and getting eyebrows under control, but if you have a uni-brow then you will need a more long term solution otherwise you could end up plucking your eyebrows every day!
Look into laser treatments or electrolysis for a more long lasting solution.
Feb 18, 2013 | Health & Beauty
How do you put a preset in Mitutoyo uni-mics?
Normally you would adjust it to the part being measured then press the 'Zero' button to zero out the display. Now every time you measure the same type of part, it should read zero or the dimension plus or minus from that zero point.
Nov 20, 2012 | Mitutoyo 317-351 Digital...
What are the float heights on a xj550 and how is it measured
If u turn the carb upside down the top of float should b level with bowl mounting suface.that should work the needle and seat properly...
Sep 08, 2012 | 1981 Yamaha-1983 Xj550 Xj 550 Maxim Seca...
Need a replacement battery for Dl1/3N duracell 3v
Here is a list of equialent batteries that are calimed to be able to replace the one you specify.
Equivalent Batteries Cross Reference: Duracell DL-1/3N, 3N, Ray-O-Vac 867, 2L76, Energizer 2L76BP, 2L76-BP, CR1108, IEC CR11108, CR1-3N, DL1-3N, Dantona Comp 15, Duracell DL1/3N, NL1/3N, Energizer LR1/3N, Eveready 2L76, L76BP, I.E.C. 3V CR1/3N, CR1/3N, CR11108, Innotek M041101, Kodak K58L, National HM-N, NR-52, NEDA 5008L, 5008LC, Nikon F-1, Sony CR1/3N, Varta CR1/3N, LaserMax LMS-1/3N, LaserMax LMS-1/3N 5PK, LaserMax LMS-UNI-G
May 17, 2011 | Starrett D125 Digitape 1Inch x 25...
How do I measure the area of a room using a
it is still length times width. the laser must turn 90 degrees or the measurements will be off slightly. Im not sure which laser you have but the one i use says store on one of the buttons and i use it to store distance one
Dec 17, 2009 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
44 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
