Question about Linksys WRT120N Wireless Router
Wrt120n hacked my linksys had the default username/password and had been hacked. i cannot login with the admin password
    Scholar:
  • 89 Answers
Press the reset button on the router for 30 seconds.
Once its completed you will be able to login with default password.
Posted on Jun 19, 2014
SOURCE: RESET PASSWORD
press the rest botten in the back for 25 sec. This should set it back. You can also call the company for free and they can tell you if this does not work.
Posted on Sep 16, 2007
  • 11 Answers
SOURCE: password doesn't accept
Try just using admin in the password....leave the username blank.
Posted on May 12, 2009
shadow83
  • 496 Answers
SOURCE: I am trying to access my Linksys wag 200 g
try resetting the router by holding the reset button on the back for about 30 seconds then try the defauld password with no username and yes the default is admin
Posted on Oct 01, 2009
govinda123
  • 2263 Answers
SOURCE: linksys router G - buddy forgot password
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Posted on Mar 15, 2010
  • 942 Answers
SOURCE: i need to reset default username and password for
Just reset your router and use (admin) for user name and password. To reset your router you can see a small hole in your router which is labeled reset. Use a pin and insert it to the hole and push.
Posted on May 25, 2010
What is default login user name and password
leave username field blank, password is admin
Dec 02, 2013 | Linksys WRT120N Router
Linskys e1000 reset and password
Hello from here you can download a manual:
http://homesupport.cisco.com/en-us/support/routers/E1000
You need to install Cisco Connect software.
To reset it you have to press a small button at the back of the router
With power on.
E1000 Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Good luck
Oct 29, 2012 | Cisco Linksys Wireless N Home Router...
I need a network name and password for my linksys router WRT120N for internet access thru my blu ray
Try the following Username: admin Password: admin Username: admin Password: leave it (blank)
Mar 04, 2012 | Linksys WRT120N Wireless Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I want to change my id user name & password for WRT120N. But I also can't find the program in my computer. Please assit me. Thanks,
In order to access your WRT120N control panel UNDER FACTORY SETTINGS, you must navigate to http://192.168.1.1 in your web browser.
According to Cisco's support site, the default username for the WRT120N will be NULL (left blank) and the password will be "admin".
Once you reach the control panel, navigate to the 'Administration' section, where you should be able to change your username and password.
NOTE: If this does not work, you may want to look into performing a factory reset of your device.
Jun 07, 2011 | Linksys WRT120N Router
I cant login to my routers thing
If you have forgotten your login password:
Perform a Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 24, 2011 | Linksys WRT120N Router
Can't get in to my router with admin
You can reset the Linksys back to the default settings by -
Power up the Linksys press and hold the pinhole RESET button for 30 secs.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 29, 2011 | Linksys WRT120N Router
Password for wrt120n
Default factory settings for this router:
IP address: 192.168.1.1
username: (left blank)
password: admin
If this username and password doesn't work because it was changed, press and hold the reset button on the rear of the router for 30 seconds. This will reset the router to factory defaults.
Apr 06, 2010 | Linksys WRT120N Router
Password problem
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." Once you are past the login screen, you are able to reconfigure the LinkSys router
Aug 10, 2007 | Linksys NSS4000
Linksys WRT120N Wireless Router Logo
50 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
