Question about Garden
Have a older GTH 220 Husgvarna rider
I have a older Husqvarna GTH 220 that wont go forward or reverse, was working fine when starting up hill and spinning tire and after several attempts it finally would not move and made a "clanging" noise after looking at drive belt and seeing it was shot but not broken I purchased a new one, after installing go figure " bad news" same ol same ol. Is it as bad as I am assuming or can this be repaired?
EarthJam
  • 23 Answers
SOURCE: Craftsman 22 HP automatic/46 How to install drive belt
Hey jim the drive belt connects to the fron of the machine Just above the PTO clutch. connected to the vertical crank on the engine. It slips through a series of pullies to the back side od the mower. One pully will be on a tention spring. that is your golden ticket to getting the tention you need.
Looking at the pullys. for routing your new belt. V pullies for the inside portion of the belt and flat pullies for the outside.
You can usualyl take the chassis and pedals off as needed. the pebals have pins holding them on.
the seat has a safty switch that gets unplugged.
There are bolts hidden under the foot map as well which snaps up and down careful with these as that mat will never be the same if you break the clips.
THe back of the mower near and above the gastank you will see a pull thats ontop of a hydrostatic pump thats the last pully.
I have done these before without removing the body. However its not easy and you had better be limber.
Ohh and of course remove any decking under the mower for mowing lawns. =) i hhope this helps if i see a diagram i will try to link you. GL buddy -Jeff in alaska
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: john deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
Posted on May 26, 2009
  • 376 Answers
SOURCE: need to find illustration of mower deck drive belt
Posted on Jun 01, 2009
  • 376 Answers
SOURCE: i need a diagram to install a drive belt for this tractor
I need the model number under the seat to get you a diagram.
Posted on Jun 12, 2009
  • 32 Answers
SOURCE: MTD Yard Machine does not go forward or reverse - I replaced belt
I think that the belt is not on right. if you look at the belt diagram from the top, then on the left side then the belt is hooked up to nothing. on the right side then the belt goes through the left side of the clutch pulley.
Posted on Jun 20, 2009
MY HUSQVARNA YTH24K48 MOWER WILL BARELY MOVE FORWARD OR REVERSE. I CHECKED THE FREEWHEELING MECHANISM AND IT WAS WORKING PROPERLY. LOOKING UNDER THE MOWER AS WELL AS I COULD, IT SEEMED FINE.
sounds like the drive belt or belts are worn out. replace both in order for it to work properly .replacing one wont work. replace them as a pair.
Nov 05, 2016 | Husqvarna Garden
Is there a solution for forward and reverse selector not functioning?
Make sure the trans axle free wheel lever is in the drive position
Oct 13, 2015 | Husqvarna Garden
My Husqvarna Rider 16c wont reverse - first it was slow in reverse then not at all
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
Feb 12, 2013 | Husqvarna Garden
Husqvarna Riding mower wont reverse gth2350 riding mower
I think theres 2 flow paths forward and reverse try checking the fluid level you may have to lower the rear end out of the machine or most all ridders ive seen allow you to take the backing plate off and then block the rear tires off the ground the fluid level should be about and inch from the top of the threads... if yours has a resivor off to the side with a breather fill it to the bottom of the threads... now that the fluid is full and up on blocks or jack stands start the engine and at an idle put it all the way forward to flush the bubles out this has to be done in small chunks 5 minutes forward and then laiter go 10 back let sit for 20 minutes in between and check the fluid level a couple of times to see if it whent down from this... best of luck hope this helped
Oct 03, 2012 | Husqvarna "GTH24V52LS 52"" Kawasaki 726cc...
Zero Turn mower no power in forward - power fine in reverse
yes check for play in linkage bushings the look for a adjustable rod
May 28, 2012 | Garden
I have a GTH 200 54" cut Husqvarna riding lawn mower. I can't get the front tire off. How do you take the black rubber covering off. It doesn't just pull off.
1) Use a pair of pliers to grab the entire boot, then careful pull it off so you don't tear it.
2) Use a flat tip screwdriver to remove the C clip
3) Remove the wheel by lifting forward and off.
Hope this helps Tim
Apr 19, 2011 | Husqvarna Garden
Clutch adjustment
I had the exact same problem on my Husq 2148 which arose just after a new drive belt was put on. There is a cage around the front, engine, pulley which keeps the belt from flying off I guess. After staring at the belt for a long, 2 beers, time I discovered the repair guy had put the belt inside the cage on one side, where it is supposed to be, but outside the cage on the other side. This caused the problem you described and it ran much better in reverse than forward. If your problem arose after a belt change, I would start looking there, if not then I would check the 2 springs which keep back tension on the pedal. It took me 3 more beers to get the thing put on right.
May 30, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Oct 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
