Question about Refrigerators
Turn off ice maker on ge model gsh25jfxn bb - Refrigerators
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: We have a ge frig
A 1/2 second on, 1/2 second off blinking indicates a fault condition with the icemaker. It could be an open or shorted thermistor, or a harvest cycle taking longer than 30 minutes. Check for a stuck ejector - caused by a cube that was not cleared or a mechanical problem. Other causes can be bad icemaker heater, control board, thermal cut out, or bad motor. Essentially, if you don't have a physical blockage, you will have to replace the icemaker.
Posted on Sep 09, 2008
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
  • 1891 Answers
SOURCE: GE Refrig. Water leaking on floor after ice maker stopped
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
Posted on Jul 16, 2010
Refrigerator GE SXS water dispenser works intermittently, ice etc works fine
I believe that you likely have a defective dispenser switch located at part location #72 in photo=> HERE This is that part number=> WR23X10224 Micro Switch I'm here should you have question, Thanks, Sea Breeze
Oct 06, 2015 | GE Refrigerators
How do I turn the icemaker off; it is making too much ice, GE model GSH25JFXN WW?
This is a quick guess. Look at the top of the ice bin. Many refrigerators stop the ice maker with a wire bale that rides up on the ice. Raise the bale and it should latch in place above the ice and shut off the icemaker.
Aug 14, 2014 | Refrigerators
How do I turn the icemaker off, too much ice, GE model GSH25JFXN WW?
Move the feeler arm above the ice bin to the up(off) position.
Below is a link to a GE side by side refrigerator manual. It may not be the exact one for your fridge. Page 20 of General Electric Side by Side Refrigerator Owner Manual...
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to...
Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
Aug 04, 2017 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
GE GSH25JFXN ice maker not working; would say it worked Thur 5/5, but was empty by Fri 5/6 early pm; did not refill over-night. Reset it once before, bu -- senior moment time -- I don't recall the...
you can try to reset by pulling off the off the white cover and with insulated wire or paper clip held by insulated pliers make a u shape and insert one end in H terminal and one in T terminal , leave for about 7 seconds until unit gets moving on it's own, then you will see if everything progresses normally. it should heat the bottom, turn through dumping the ice and refill with water . Did I mention insulated wire..
May 07, 2011 | Refrigerators
Ice maker on GE refrigerator model TBX21C1 BRRWW will not stop making ice cubes even when the shut off arm is in the raise position
You have a stuck micro switch in the ice maker. Try taking out the maker and remove the metal plate 4 screws and you will see the switch that work on a cam rod. I believe you will find your problem. BB
Dec 15, 2009 | GE Refrigerators
Ice maker not working
The solenoid on the back is not working or the ice maker is not calling for water.(check the solenoid first)
Jan 15, 2009 | GE Refrigerators
Water dispenser not working but ice maker does
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
