Question about Amana SXD524VW Side by Side Refrigerator
Freezer not cool enough and the Icemaker not working
Hello, My fridge is an old one ? SXD524VW year: 1997. The fridge had some water liking before and since then the Freezer not cool enough and the icemaker not working, although rarely it makes ice. I set it to the lowest temperature and it didn't help. There is no water liking anymore and water bar ok. Thanks, David
    Novelist:
  • 87 Answers
Defrost the fridge freezer for 24 hrs and before turning on check for any water leaks. Turn back on if the cabinet pulls down to temp in 12hrs you probably have a defrost heater problem if it doesnt pull down at all it could be the fan or sensor fault. Either way you would be best to contact a suitable refrig engineer. Hope this helps. fishersofcambridge
Posted on Aug 17, 2007
SOURCE:
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator not cooling, freezer is working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore elite water dispenser works but the icemaker doesn't
It is either your water valve in the back of the fridge, the module on the icemaker.
Sep 13, 2009 | Refrigerators
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
I own a three year old Whirlpool side by side fridge freezer with ice maker and water dispenser. Icemaker not now working, and fridge temperature warmer, not cooling food etc sufficiently
ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker
Hollow ice is a sign that the icemaker is not getting enough water.
You will want to make sure there is enough water coming to the fridge and any filters in the system are clean.
If you need help checking it, please post the complete model number from the fridge and I can help you more.
Nov 24, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Aug 27, 2007 | Refrigerators
Amana SXD524VW Side by Side Refrigerator Logo
216 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
