Question about Garden
How to install shield deflector on a Ariens 17.5 HP ride on Mower
Do I need to take the bracket that holds the shield to the mower deck off, before I am able to push bolt on and add spring?
  • 7 Answers
SOURCE: deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
Posted on Sep 05, 2008
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
mowerman1857
  • 389 Answers
SOURCE: ariens 1440h cutting problem
moz-screenshot.jpgGo to this site: http://www.ariens.com/corporate/pages/partsradar.aspx (copy and paste in your address bar)
follow the instructions given and you can download a VERY GOOD picture of where it goes
Posted on Sep 29, 2009
SOURCE: How much oil does my craftsman riding mower hold? ...
4.5 pints with filter or 4 pints without
Posted on Sep 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: How do I install the
Hi and welcome to FicYa, I am Kelly.
You will need to make sure that you have items 21 - 29 of this diagram: Scroll way down 75% until you see the deck and belt, then look at item 27 the deflector shield.
http://www.hammerwall.com/Manuals/Craftsman/Description/917.288031/Craftsman%20Lawn%20Tractor%2017.5%20HP%2042%20Inch%20Mower%206%20Speed/L0807249/
It is a matter of sliding the bolt throught bracket on the mower deck and making sure that the shield safety switch is actuated. (Flip up)
I also read the owner's manual (no help!). The only thing about the shield is on page 14 stating to make sure it is in place.
If your missing the hardware to install the deflector shield you can go to http:www.searspartsdirect.com and enter your model number in the search bar. You have to choose model search then click (go).
You will get this diagram if you choose mower deck:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917288030/0247/1509200/P0905008/00007?blt=06&prst=&shdMod=
Thanks for choosing FixYa,
Kelly
Posted on Apr 30, 2011
I need to installhow to install a new deflector on Craftsman mower model 917273130?
Very simple. The 6 inch or so pin that holds it on is retained by a clip on one end. To remove clip use a pair of pliers. If you work steadily and carefully you will be able to reuse this clip. After removing clip, pull the pin out. Old deflector and spring be removed now. To get the spring right you have to try it in position before installing it. Just remember that the spring is holding the deflector down so when you are done installing, when you pick up on the deflector there is pressure holding it down. Don't put the pin clip on until you verify the spring force is correct because getting that spring clip off is the Hardesty pay off the job.
Oct 11, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I level the mower deck on an Ariens 42 in. 17.5 HP Riding Lawn Mower ?
With the mower on a flat surface and the correct air pressure in the tires take a tape measure and measure all four corners of the deck. Then loosen or tighten the adjusting nuts that the deck attaches to the mower frame to get the same measurements on all four corners.
Sep 09, 2014 | Garden
How do I replace deflctor shield
You have to hold the spring and deflector in the loaded position (forcing against the spring force) while you feed the pin thru the deflector and spring and back thru the deflector and intor the deck bracket.
Jul 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to replace deck belt on ariens model 960160027 lawn vtractor
Please go to the Ariens website and download a manual for your mower.
Jun 29, 2014 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
Install a deflector shield on a Sears 54" mower deck
Whats the question? If you are removing and replacing the deflector,there is two to four bolts holding it on the tractor. I'am not for sure,about the amount of bolts holding the deflector on. I don't know what model # ,you have. If by chance,you have a grass catcher installed,it will have to be removed,to get access to the bolts. Once again,i don't know the model if you can have to jack up the tractor or not,even after putting the mover up to the highest setting. This is about all i know,at this point. Hope what i suggested to you,helps. Sincerely,Brad Locke DTD. 12/03/15
Sep 02, 2013 | Sears Garden
Deflector installation
Where does it go the mower deck or the engine. On a John Deere rider like we have , it goes on the mower deck that is located under the tractor or mower. On the right side ( when sitting on seat) ours is on the right and it is for the bag or box attachment for clippings and or debris. A plastic cover is held on by a short rubber bungie on each side that as a hook on each end and it hooks around a small bracket to the front and a small bracket to the rear...Do you still have owners manual ?. most guys keep them in some drawer or shelf in the garage or tool shed area ...good luck...
Jun 05, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I install the deflector shield on a Craftsman LT1000 lawn tractor, model # 917.274351?
Have you checked if it has a nut on the other end which is just turning round with the bolt ?
Sep 01, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower deck slows and stops when I turn my Simplicity riding mower to the left,
HI,
The simplicity has a a two point mounting system for the deck. It attaches to the front axle which has two runners that go to the front axle's rear support bracket.
Closely check the runners near where the pins that hold the mower deck. They are known for cracking and breakage. Secondly, closely check the decks metal center support bracket, it bolts to the center of the deck and supports the idler pulleys as well as the deck alignment and mounting. Those, too, are known to crack near the front just behind the front pulley.
Aug 25, 2012 | Garden
How do I install the deflector shield on a Craftsman riding mower, model # 917.288031?
Kelly
Apr 30, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
