How do I install a Toshiba CD-RW DVD DRIVE TS-H492
    Novelist:
  • 148 Answers
They can't be both Master Drives, i.e. you will have to play with the Drives Jumpers, i.e. make one of them Master and the other Slave OR if you are using the 80 wire IDE cable (PATA) then choosing Cable Select (CS) on both should do the trick.
Posted on May 03, 2013
4 Suggested Answers
pk86bhat
  • 75 Answers
SOURCE: Samsung TS-H492 Jumper
hai
if u have two seperate data cable to hard disk and dvd rw,there is no big changes to made in jumpers,but u have only one data cable u should select jumper as a master to hard disk and slave to dvd rw,
basic identification to master jumper is that ,it place is close to data cables ,and slave is next pin,in typical models
also u se the detail in hdd and dvd rw's jumper locations
thanks
prasanna
Posted on Mar 01, 2008
  • 198 Answers
SOURCE: Samsung TS-H492 CD-RW Combo
There may be an easier solution. If you remember a time when it worked, do a system restore to that date. If that doesn't work, then try the following. Oddly enough, you don't need drivers for the CD/DVD drives--they aren't even recognized unless you have a non-microsoft burning program. Find out what burning software you have-- I recommend downloading Belarc Advisor, a free program which not only tells you everything in your computer, with model numbers for hardware and all of your software (with their unique codes), but will also inform you if you are missing any needed Windows updates. Once you know what you have,you have to seek a download or upgrade at the computer manufacturer's website, as it may be a special program not related to the burning software from the software manufacturer. That may do the trick--sounds to me as if your burning software is corrupted.
Posted on Mar 15, 2008
jonags3
  • 83 Answers
SOURCE: Toshiba SD R2312 CD-RW/DVD-ROM
I have the same problem like you.one of the expert shared to me that my burner has faulted. I thing your problem is worse than mine cause I can still read cd rom vcd/ DVD files and movies. Just finfd new one that will give you quality output.
Posted on Oct 22, 2008
How can i burn dvd in combo ts-h492,
you can not burn a dvd with a dvd rom you will need a dvd-rw not a cd-rw
Dec 22, 2010 | Samsung TS-H492 (TSH492AWRBH)...
Need diagram info for master and slave driver
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Dec 06, 2010 | Samsung TS-H492 (TSH492AWRBH)...
My Toshiba ts-h653 cd/dvd RW drive failed. the
If the drive is trashed, just force the drawer open. If you don't want to do that, you should be able to disassemble the drive enough to get the disk out by removing screws... Sometimes the screws are underneath stickers, or warranty stickers, etc etc.
May 09, 2010 | HP Computers & Internet
This thing can see cd's, but can't see a dvd,ut will record cd but not dvd
I don't know what OS you are using, but NORMALLY you can "Burn" a CD "Natively" IE: Without using any other software. However you CANNOT for a DVD. You need to get a DVD "Burner". Unless of course you are using Vista or Win 7. Then, you can burn both "natively".
Feb 13, 2010 | Samsung TS-H492 (TSH492AWRBH)...
My samsung ts-h492 does not read cd
you'll have to clean the lens with the help of a service engineer...even after the same problem occuring means you'll have to check the data cable...if found any error replace it...
Jul 05, 2009 | Samsung TS-H492 (TSH492AWRBH)...
Drive not working
try to check the connection of that device of it is properly attach.
Jun 16, 2009 | Samsung TS-H492 (TSH492AWRBH)...
I have a question, I install a Hard Disk as a slave with the CD ROOM data buss, but when I turn on the pc the cd room wont be recognized, What would you recommended
Do you have both a primary & secondary IDE controller? Make each Master on its own controller. Or make the hard drive master with the DVD as the slave on the same controller.
Mar 04, 2009 | Samsung TS-H492 (TSH492AWRBH)...
are you using a single IDE cable with your H/Disk? if yes! check, the jumper connections of your CD-ROM,maybe the are both in the master position ,change the jumper of your CD_ROM to slave position.or use another cable for your CD-ROM.if doe'snt work go to BIOS SETUP,set the settings to default SETUP.then restart your PC.
Mar 10, 2008 | Samsung TS-H492 (TSH492AWRBH)...
hai
thanks
prasanna
Mar 01, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
