Question about Garden
How to install Shield Deflector on Ariens 17.5 Hp ride on mower
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: How do I install the
Hi and welcome to FicYa, I am Kelly.
You will need to make sure that you have items 21 - 29 of this diagram: Scroll way down 75% until you see the deck and belt, then look at item 27 the deflector shield.
http://www.hammerwall.com/Manuals/Craftsman/Description/917.288031/Craftsman%20Lawn%20Tractor%2017.5%20HP%2042%20Inch%20Mower%206%20Speed/L0807249/
It is a matter of sliding the bolt throught bracket on the mower deck and making sure that the shield safety switch is actuated. (Flip up)
I also read the owner's manual (no help!). The only thing about the shield is on page 14 stating to make sure it is in place.
If your missing the hardware to install the deflector shield you can go to http:www.searspartsdirect.com and enter your model number in the search bar. You have to choose model search then click (go).
You will get this diagram if you choose mower deck:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917288030/0247/1509200/P0905008/00007?blt=06&prst=&shdMod=
Thanks for choosing FixYa,
Kelly
Posted on Apr 30, 2011
Having trouble removing drive belt
Remove belt from opposite end so you don't fight with clutch end.
Jul 02, 2015 | Ariens Max Zoom 60 in. 25 HP Kohler...
I'm trying to replace the deflector shield on my craftsman LT1000 riding mower. I have purchased the shield but the rod that holds it on ( which is on the mower) is capped at both ends not allowing them to...
You don't. One one those caps must be removed. Don't lose it as you need to put it back on provided you don't destroy it. It pressed on so will need to be knocked off using a spanner and a hammer. Also after you remove the rod that spring will be hard to get back into position.
Jul 25, 2014 | Garden
How do I replace deflctor shield
You have to hold the spring and deflector in the loaded position (forcing against the spring force) while you feed the pin thru the deflector and spring and back thru the deflector and intor the deck bracket.
Jul 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why wont an ariens mower turn over?
dead battery or the brake is not depressed far enough for the safety to not work
May 17, 2014 | Ariens 46 in. 20 HP Hydrostatic Riding...
Install a deflector shield on a Sears 54" mower deck
Whats the question? If you are removing and replacing the deflector,there is two to four bolts holding it on the tractor. I'am not for sure,about the amount of bolts holding the deflector on. I don't know what model # ,you have. If by chance,you have a grass catcher installed,it will have to be removed,to get access to the bolts. Once again,i don't know the model if you can have to jack up the tractor or not,even after putting the mover up to the highest setting. This is about all i know,at this point. Hope what i suggested to you,helps. Sincerely,Brad Locke DTD. 12/03/15
Sep 02, 2013 | Sears Garden
How do I install the deflector shield on a Craftsman LT1000 lawn tractor, model # 917.274351?
Have you checked if it has a nut on the other end which is just turning round with the bolt ?
Sep 01, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I install the deflector shield on a Craftsman riding mower, model # 917.288031?
Kelly
Apr 30, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Is there a way to put the deflector shield in an up position when the mower is not being used?
Find a bungee cord at walmart, this is a heavy stretchable cord with metal hooks on the end.
drill a hole through the outside edge of the shield.
when you are not mowing, put one of the hooks through the drilled hole and wrap the other end of the bungee cord around the grip handle or the steering wheel.
do not hang the bungee cord anywhere on the mower when it is in use as you will somehow turn it into a hurtling projectile of death or injury
there you go!
Mar 01, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Deflector shield will not stay in place due to the loss of part nut,push. Any suggestions?
drill a hole in the shaft where the push nut went and use a cotter pin and washer to take its place
Jul 12, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
