Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Install Shield Deflector on Ariens Ride On Mower
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: How do I install the
Hi and welcome to FicYa, I am Kelly.
You will need to make sure that you have items 21 - 29 of this diagram: Scroll way down 75% until you see the deck and belt, then look at item 27 the deflector shield.
http://www.hammerwall.com/Manuals/Craftsman/Description/917.288031/Craftsman%20Lawn%20Tractor%2017.5%20HP%2042%20Inch%20Mower%206%20Speed/L0807249/
It is a matter of sliding the bolt throught bracket on the mower deck and making sure that the shield safety switch is actuated. (Flip up)
I also read the owner's manual (no help!). The only thing about the shield is on page 14 stating to make sure it is in place.
If your missing the hardware to install the deflector shield you can go to http:www.searspartsdirect.com and enter your model number in the search bar. You have to choose model search then click (go).
You will get this diagram if you choose mower deck:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917288030/0247/1509200/P0905008/00007?blt=06&prst=&shdMod=
Thanks for choosing FixYa,
Kelly
Posted on Apr 30, 2011
  • 5 Answers
SOURCE: How do I install the deflector shield on a Craftsman LT1000 lawn tractor, model # 917.274351?
Have you checked if it has a nut on the other end which is just turning round with the bolt ?
Posted on Oct 13, 2012
I'm trying to replace the deflector shield on my craftsman LT1000 riding mower. I have purchased the shield but the rod that holds it on ( which is on the mower) is capped at both ends not allowing them to...
You don't. One one those caps must be removed. Don't lose it as you need to put it back on provided you don't destroy it. It pressed on so will need to be knocked off using a spanner and a hammer. Also after you remove the rod that spring will be hard to get back into position.
Jul 25, 2014 | Garden
Install a deflector shield on a Sears 54" mower deck
Whats the question? If you are removing and replacing the deflector,there is two to four bolts holding it on the tractor. I'am not for sure,about the amount of bolts holding the deflector on. I don't know what model # ,you have. If by chance,you have a grass catcher installed,it will have to be removed,to get access to the bolts. Once again,i don't know the model if you can have to jack up the tractor or not,even after putting the mover up to the highest setting. This is about all i know,at this point. Hope what i suggested to you,helps. Sincerely,Brad Locke DTD. 12/03/15
Sep 02, 2013 | Sears Garden
Sep 01, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I install the deflector shield on a Craftsman riding mower, model # 917.288031?
Kelly
Apr 30, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Is there a way to put the deflector shield in an up position when the mower is not being used?
Find a bungee cord at walmart, this is a heavy stretchable cord with metal hooks on the end.
drill a hole through the outside edge of the shield.
when you are not mowing, put one of the hooks through the drilled hole and wrap the other end of the bungee cord around the grip handle or the steering wheel.
do not hang the bungee cord anywhere on the mower when it is in use as you will somehow turn it into a hurtling projectile of death or injury
there you go!
Mar 01, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Are all drive belts on lawnmowers compatible I have ariens ride-on lawnmower
All belts are not created equal. I recommend staying with the manufacturer's belt. Riding mower belts have to take a lot of torque when engaged and a lesser belt will have much less life. You may end up changing belts several times to learn a valuable lesson.
May 01, 2010 | Ariens 34 In. Zoom Series Riding Mower
Ariens ride on mower
The most likely cause of the mower belt coming off is a bearing in the quill assembly which are the upright units that have the pulley on top and the mower blade on the bottom, what usually happens is a bearing statrts to go bad, which allows the pulley to startmoving out of alignment with the other pulleys which causes the belt to ride up on a flange and come off. Usually I reccommend that when you replace one bearing or complete quill assembly you replace all bearings, or quill assemblies this way everything is in like new condition and the problem should be solved. Hope This Helps Don
Nov 01, 2009 | Ariens Garden
Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
60 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
