Question about As Seen On TV Pocket Hose 50 Lightweight Expandable Hose With Sprayer Nozzle
Pocket hose sprayer attacment leaks; have tried several. Anyway to stop leak.
Pocket hose nozzle leaks
Spray not working, doesn't stop water from faucet.
It sounds like a kinked hose under the sink or a clogged nozzle. Unscrew the nozzle from the sprayer and check for calcium buildup. New parts can be purchased cheaply from the local hardware store, take the old parts in and a sales rep can help you with the correct parts. Some sprayers have replacement nozzles...unscrew the old and screw in the new.
Sep 20, 2015 | Plumbing
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
Feb 22, 2014 | WD-40 Foaming Bike Wash 1L With Sprayer
Spray nozzle leaks
That would be your best bet very well could be a bad sprayer housing
Jan 23, 2018 | Rohl Plumbing
Kitchen faucet head cane off the rinse hose
have you tried to purchase a new hose it comes with the
sprayer head shut the water off so no possible leaks take the hose off and see if walmart has one
Jul 09, 2017 | Globe Union Lavatory Faucet
Sprayer hose leaks at the base of the faucet after sprayer replacement and thread tape application
Make sure the internal washer is intact and there is no damage to the parts that you are connecting together. Also, do not use too much tape....one or two winds is enough and wind in in the direction of the action of the female connector (clockwise) so you don't bunch it up in one spot.
May 05, 2012 | Plumbing
Only one winshied wiper spray works
Check the rubber hoses to the sprayers. If they are on the hood they can come unplugged when you open it. Have a friend work the sprayers as you watch for leaks. An old toothbrush can be used to clean spray nozzles by scrubbing over the hole.
Feb 13, 2011 | 2004 Chevrolet Cavalier
Water leaking down sprayer hose under sink. American Standard Jasmine high flow 3821.831 or 834.
They didn't put the attachment on correctly. Look at the directions for the sprayer. It's a black little piece with grey clips. U need to put it on correctly so it seals. That should stop the leak!
Jan 04, 2010 | American Standard Plumbing
Golf A4 mk4 2.0 wipper washer issue...
Get a can of duster from Walmart, open your hood and remove the hose from the nozzles where the fluid comes out (just twist and pull the hose) take the can of duster and spray into the nozzles from the top of the hood, do this for each hole in both sprayers. Replace the hoses and you should be good!
Feb 07, 2009 | 1999 Volkswagen Golf
Immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
As Seen On TV Pocket Hose 50 Lightweight Expandable Hose With Sprayer Nozzle Logo
186 people viewed this question
Top As Seen On TV Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an As Seen On TV Garden Expert? Answer questions, earn points and help others
