Question about Electrical Supplies
Wiring diagram kirloskar alternator
Alternator winding diagram & avr circuit diagram
2 Suggested Answers
  • 45363 Answers
SOURCE: wiring cummins gen with alternator withSx440 avr
With a gen set that big I strongly recommend a qualified electrician for the job as one touch and you will be charcoal.
Posted on Apr 21, 2013
Denon AVR-3801 lights up,makes rapid clicking noises when amp tries to turn on. Clicking stops but unit doesn't play & sometimes the unit turns off. Occurred after lightning storm. What to do to fix?
Probably damaged by power surge. If you do not have experience diagnosing and repairing electronic circuits as well as having access to schematic diagrams then this is not a repair for you. Failure to replace all damaged components may result in damaging new parts.
Aug 16, 2016 | Denon Avr-3801 7.1 Home Theater Surround 7...
Need wiring diagram,from alternator to plug-ins for briggs & Stratton (3500) Elite series Model # 030208-0
No wiring diagram available from Briggs. Try re-magnetizing the rotor. No AVR or Capacitor listed in the parts list.
Disconnect the wires to brushes ( pay attention to the order) and apply 12vdc to brushes. Positive goes to brush closest to the bearing. Start the generator and check for output. If output is normal run the unit a few minutes to ensure re-magnetization then shut down normally. After shut down disconnect the 12 vdc source and re-install the previous disconnected wires. Now re start the generator and test for output should be okay provide there is no problems with the alternator. If no output during the above re-magnetization then your rotor windings my burned out.
Oct 10, 2014 | Briggs & Stratton Gas Powered 3500-4375...
My 3kva petrol generatori change lot of avr after 1 hours it burn
If I understand your problem, you replace the AVR only to have it go bad after only ! hour. This is a very strong indication that the winding of the rotating field has a short circuit . If you do nor have meters and equipment to test, try this trick. In the wiring from the regulator to the slipring brushes, cut the wire and splice in a automotive fuse holder with a 3 amp fuse. If you run the unit and it blows the fuse, you then know the problem. Hope this helps you, Robert
Mar 26, 2013 | Electrical Supplies
Have B&S 7500 Vanguard Genset. No Output. Have checked windings as per info on this site. Applied 12Vdc direct to the brushes and get 160Vac output. There are black/red wires from brushes that go back...
Hi, a word of caution, use a 9volt battery instead of 12v to check the rotating field winding. The 12volts from a car battery or battery charger can burn out windings in a generator. I would say that your avr is pooched. There are 4 leads that go back to the windings in the generator from the AVR. Two of these are connected to the power output and two go to a separate winding in the generator. This is the exciter winding and this supplies power to the avr for the rotating field. The two to the power output are voltage reference only. If your generator has these exciter winding, you should check if you have voltage there with the 9 volts applied to the rotor. If you have voltage on the power output and not on the exciter, then the exciter is shot and your avr might not be. Try this first, if you could, could you take a picture of the windings at the back end of the generator, this will confirm for me what leads you have present.
Feb 15, 2011 | Briggs & Stratton Electrical Supplies
Problem with my alpha arcam 7 amp.. internal 240v 25a fuse blows right after switching it on even when all speaker and RCA cables were disconnected.i need the schematic diagram. Where should i start the...
hi,
I have the service manual of ARCAM AVR 200 with me. send me a mail on my mail id. I will send u the service manual. its a large file having a size of 4.8 mb. I can sent it through fixya.
agingopakumar@yahoo.co.in
Check the standby transformer T752 first. if its primary winding is short the this problem can occur.
ok
Jan 17, 2011 | Arcam AVR-200
I want a generators AVR circuit diagram please
I am looking for an Avr citcuit diagram Model no. Kl-DAVR-50S.
Jul 30, 2010 | NEC Mitsubishi MGE 1800 Generator-Voltage...
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
Denon avr-5600 protection circuit.
My AVR 5600 has worked flawlessly for nearly 9 years!
Suddenly, when trying to play music (DVD or CD) through my LS32's (JBLPro), once I achieve higher volume, the receiver cuts off.... Using a Symetrex mixer, NO OVERLOAD light on the Denon, it simply cuts off!
Re-cut all the wire connectors... TV movies (5.1) work great at normal listening volumes.... but tonight, when cranking up music, the receiver simply cut off. Blinking light...
HELP
forfrance@hotmail.com
Apr 12, 2008 | Denon Audio Players & Recorders
Electrical Supplies Logo
18 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
