Power supply enp-5825 red light comes on but not green?
  • 10406 Answers
SOURCE: where to purchase a new 250w ENP-3125 power supply
Go to any computer-store, carrying your old power-supply with you,
tagging which of the connectors that you use, and which of the connectors that you do NOT use. The sales-representative can then find a "generic" power-supply with the same height/width/depth, and with the necessary connectors,
and with the necessary power-output (volts & amperes).
Posted on Jul 17, 2010
Testimonial: "thanks for that info"
bronk50
  • 27725 Answers
SOURCE: power supply nps-730ab getting red light in middle
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Oct 01, 2010
  • 1082 Answers
SOURCE: where can I buy
http://www.google.com/#q=Enhance+200W+TFX12V&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=fp6GTf6NAo7sOfKZ0eoI&sqi=2&ved=0CDUQrQQ&biw=1004&bih=583&bav=on.2,or.r_gc.r_pw.&fp=52f01a95353e1206
This is a google search which produced many hits. Mostly 49 dollars, one 'refurbished' for 17.10ish
Just click on this link to bring up same list.
Posted on Mar 21, 2011
cristi_mc
  • 55 Answers
SOURCE: I have a Power Judge
Try to measure voltage on power supply with a more acurate tester and you will see if your power tester is good or not. This is the easy way to control acuracy of your tester.
Posted on Apr 04, 2011
  • 1388 Answers
SOURCE: Dear Guru my power supply of my computer with
Do not try to fix this power supply. Better to replace with new or good used. I see many on ebay from 13.50 to 25.00. Also google that model for other options. Most likely fuse on the power supply has failed but if you bypass the fuse, with jumper wire or another fuse, will blow again. Probably capacitors. Good luck
Posted on Oct 06, 2011
Fec power adapter is not working model No enp-5825
Buy a new adaptor, The power requirements for the replacement will be on the old one. (Voltage and Wattage required.)
Feb 17, 2013 | FEC 15 Inch 250 NITS FUJITSU 4 WIRE 1.6...
WHAT IS A REMOTE ON OFF
It is the green wire in general you must plug a wire between Greens a black wire to put the power on
It called "remote on/off" because on old AT the power wasn't plugged on by the motherboard but by a switch directly wired in the PSU
Dec 17, 2012 | Enhance Technology ENP-2320, Enhance 200W...
Dear Guru my power supply of my computer with model enp-2120d doesnt work no power output so please gave me some idea or schematic diagram,thank you.
Aug 28, 2011 | Enhance Technology ENP-2120D (ENP2120D)...
My computer did not start when i tryied to turn it on, so i pushed the red butten to the side at my power suply and tryied again ther was a loud bang from the powersuply and ther was smoke comming out from...
The only thing to do at this point is to replace the Power Supply with a KNOWN to be good, compatible unit, and see if the rest of the computer hardware components are okay.
Going by your information stated that the Power Supply is an Enhance ENP-2224B SMPS, (Switched-Mode Power Supply), it is a special shape.
If it wasn't for the Slim Micro-ATX computer case you have, you could use an easy to obtain ATX form factor Power Supply.
From a quick search though it looks like a replacement unit is affordable,
http://www.censuspc.com/Enhance-ENP-2224B-2G-240W-SATA-TFX12V-P4-Power-Supply-for-Slim-microATX-Desktop-Case-Serial-ATA-Ready-bulk-pack-SKU-ENP-2224B-2G-pr-3033.html
There is simply no way to tell if the motherboard, and/or Processor, and/or Ram Memory, and/or Harddrive, etc., is okay without having power.
Unless you transfer the components on the motherboard to another working motherboard.
[NOTE*
If your Power Supply has a rocker switch on the back that lets you use 120 volts, or 220 volts, make SURE it is set to the right voltage.
USA?
120 Volts
Europe?
220 Volts
Australia?
220 Volts
Japan?
100 Volts ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 26, 2011 | Enhance Technology ENP-2224B, Enhance 240W...
The enp-2320 will not turn on, any thing i can do? is there a fuse i can replace?
Welcome I want you to help does not exist DC voltage reading was 1.5 disappear
Sep 16, 2010 | Enhance Technology ENP-2320, Enhance 200W...
Where to purchase a new 250w ENP-3125 power supply unit in the uk
Jul 17, 2010 | Biostar ENP-3125 (250w psu) 250-Watt Power...
Tvstopped working, green power light comes on, red light flashing
Most likely it has a power supply module problem. Have it looked at by a qualified service company.
Dec 08, 2009 | Sony Televison & Video
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
