Question about Dell 922 All-In-One InkJet Printer
My lexmark printer
I closed the cover of it but it froze the screen and it keeps on saying close printer cover and it doesnt print it is very loose the cover after i opened it it wont close lock but it just closes with no interlocking hope you can help me thanks sincerly nik
  • 1 more comment
  • kdgloves Nov 30, 2007
    the printer door closes but the message just keeps coming back and wont let me print. where is the hinge this post talks about
  • Anonymous Mar 12, 2014
    b 162 konica says side cover open close side cover but the side cover is closed
    b162 konica says open side cover close side cover but the side cover is closed
    Scholar:
  • 161 Answers
Yes sounds like you may have a broken or out of alignment hinge on your printer. Examine it very closely to see if you can align it without breaking it. If so try printing again to see if this fixes it. Restart your computer and printer after alignment of door.
Posted on Aug 06, 2007
SOURCE:
Wont let me print
The error code "EC5" indicates a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Jan 07, 2012 | Lexmark X2670 All-In-One Printer
Lexmark z2300 keeps printing blank sheets
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Oct 06, 2011 | Lexmark Z2300 InkJet Printer
Screen displays message saying "cover
It could be that the cover sensor is stuck or could also be due to the cartridges in the printer. Please follow the steps below on how to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. Reinsert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, reload some sheets of paper and try to print a document again to verify that problem is fixed.
If the problem continues, please contact the Lexmark Technical Support Center for additional assistance.
Sep 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
When i try to print on my Lexmark 2300 it keeps saying scanner unit is open, but it isn't. I've turned it off and on opened and closed the unit but this hasn't helped
It could be the cartridges in the carrier. Please follow the steps below to identify and fix the problem:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
5. Unplug and re-plug the printer into the power outlet to reset it.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You may also try to insert a different known working cartridge to determine if the cartridge you are currently using is faulty.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark Z2300 InkJet Printer
I have a Lexmark x4690 and the printer keeps telling me I have an alignment problem. I say ok to doing the alignment but when the paper feeds through there is no ink on the page. Also, if I try to print...
The error could be due to the cartridges in the printer. Please follow steps below to identify and fix the problem:
3. Remove both cartridges from the carrier. Check the encoder strip (transparent strip behind the cartridge carrier) and make sure it is not unseated from its position.
6. When the printer turns on, check for any errors. If alignment error is displayed on the screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 10, 2011 | Lexmark X4690 Wireless InkJet Printer
My lexmardk z645 saying its printing...when it begins...it makes an annoying sound and says out of paper....
Try to empty the printer of sheets of paper. Open the cover where the cartridges and remove the cartridges. Check for any loose strips inside the printer or maybe pieces of paper that got torn. If none found, close the cover. Unplug the printer from the power source, replug after 30 seconds. When the printer's ready, reload the cartridges. Load some paper, don't overload. Try to print again. If problem continues, you may be having a hardware problem. I suggest you contact Lexmark technical support to further investigate the problem.
Aug 31, 2010 | Lexmark Z640 InkJet Printer
Lexmark P3150 says cover is open
May be the cartridge not fitted properly.
Also try to unplug the printer during PC on. and then replug it.
Try to power off printer, restart PC and disconnect USB, then connect after restart PC.
Let me know if you need further help.
Oct 04, 2008 | Lexmark P3150 All-In-One InkJet Printer
The scanner cover is closed, however I get an error message saying it's open. The unit will not print, copy or scan
I just changed the cartridges, however I get an error message saying " Cover open / close cover / change cartridge " error . The unit will not print, copy or scan. Any suggestions? Thanks
Jul 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
I have a lexmark x4550. It keeps saying "Cover OPen" and its closed
Error 30 Top Cover Open or Print Cartridge Missing Make sure the spring-mounted pin on the print head shroud is installed properly and that it is detected by the ramp on the print cartridge as the cover closes. The pin should enter the tower on the HVPS and depress the cover switch.
Different printer, similar issue. May help.
Jun 02, 2008 | Lexmark Office Equipment & Supplies
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
