Question about Janome Sewing Machines
Jenome model 385.4052LX200
Sewing backwards
2 Suggested Answers
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
How do i fix the timing on my jenome my excel x 23
It's pretty rare for the timing to go out on a sewing machine -- it's almost always preceded by loud noises, broken needles and bad words. What's your machine doing (or not doing) to make you think the timing is out? Is it skipping stitches? The stitches look like
_ _______ _ _ ____ _ ___________ instead of _ _ _ _ _ ? If so, the problem is likely to be a needle in backwards, a damaged needle, or a needle that's too small for the thickness of fabric.
Or is it making loops on the front or back of the fabric? That's usually a misthreading problem. See: http://www.picturetrail.com/sfx/album/view/22521551
May 07, 2014 | Sewing Machines
My friend bought jenome sewing machine. It is working very well except that it only sew in reverse (backwards). Could it be that the reverse button got stuck or is there a setting that needs to be done?
button in centre of stitch length control is probably gummed up and stuck lubricate with penetrating oil and wind stich control backwards and forwards to see if centre knob starts to move. Remove arm top cover and do same to mechanism visible from above
Feb 19, 2014 | Janome Sewing Machines
What is the best kind of sewing machine to buy for someone who sews?
i would suggest a good machine that is around 300 dollars is the Kenmore Model number 19110, my wife just bought one and loves it. its made by Jenome.
Mar 11, 2011 | Janome Memory Craft 9000 Computerized...
Looking for Jenome memory Craft 3000 sewing machine manual
This is only a partial manual, however it is free from the Janome website.
http://www.janome.com/documents/File/ManualFile/MC3000.pdf
Hope this helps!
Sep 08, 2010 | Janome Memory Craft 3000
As a novice, I am interested in purchasing an embroidery/sewing combo machine. Which one is better (w/ less problems & under $1000.) ?
I got my Jenome MC10001 5 years ago. It was the top of the line combo. Within 5 years Jenome retired it, I also found that the manufacturer was not keeping the connections to the PC current. As well the machine drivers will only connect to a 32 bit PC. Bottom line. Sewing machine manufacturers want to produce computerized machine$ but are not interested in designing their machines to accomodate future technology through firmware upgrades or replacable connection ports. Your machine will likely be obsolete not because of dealer support but because of changing external technology. Also support is not as good as from computer software companies. If you get a embrodery machine, you need software and expensive threads.
Think twice.
Jun 17, 2010 | Brother CS6000i Computerized Sewing...
Where can I buy parts? Will my local dealer have
try this link
www.sewvacdirect.com/janome660jem.htm
www.allbrands.com/products/abp14452.html
www.bizrate.com/sewing-machines/bobbins-for-janome-sewing-machines/ -
Sep 07, 2009 | Janome Jem Gold 660 Sewing Machine
Lost manual need help in threading machine
Thread it though the tension then the take up lever then the needle. I think your machine has numbers and arrows showing you which way to go.
sewman7
Apr 30, 2009 | Sewing Machines
Timing
I need instructions for timing a singer 1036 we replaced the gears under the feed dogs and now we need to know how to time the maching. Can you help?
thanks Shirlene Jones
Jun 08, 2008 | Janome Sewing Machines
Sewing Machines Logo
44 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
