Blenders
Problem for Blenders
Generic problem for all Blenders
Bamix stick blender Handle vib...
By nkporter on Mar 13, 2009
 Bamix may be 12 years old,  but used only a few times and not within the last 9 years.
Might it be saved or is it done for.
Frozen?
Manual instructions say if shaft does not turn, unscrew blade holder CLOCKWISE.  It will not turn
Best Solution
posted on Mar 13, 2009
Very Helpful)
foggy13
Rank: Apprentice
Rating: 92%, 3 votes
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Blenders
Questions and Unsolved Problems for Blenders
Answer
pour spout broken on back to basic sp smoothie 600
Answer
Hi,I have a philips HR1366 hand held blender and my dog has chewed the white fluted lid that sits on... (More)
Answer
the lights are working so there is power. When I push the start button nothing happens.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Blenders:
Top Blender Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Blender Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
