Question about Panasonic Computers & Internet
Panasonic tv troubleshooting - Panasonic Computers & Internet
Free tv troubleshooting
probably needs one or both of the sustain boards, i would invest a little money and have a professional check and diagnose it, I feel this presents to big a problem for the layman.
Jun 20, 2013 | Panasonic Televison & Video
Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Nov 20, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
My panasonic tc-l32c12 red light blinks cuts on and off and smokes
It has badly shorted out circuits. It will need in-depth troubleshooting. Look inside at the power supply module and the bcaklights inverter boards for burnt components, then repalce the bad modules.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 25, 2011 | Panasonic Viera TC-L32C12 32 in. LCD TV
We bought a new Panasonic high definition TV TC-L42D2 and we are unable to see a picture when we try to play a DVD on our Panasonic SC-HT650 System. We only get audio on the DVD. We are sure we have the...
So what's different? The TV. Anything else like the video type (s-video, composite, component)?
Perhaps if you described what cable is carrying video and the point-to-point connection to the TC-L42D2 we'd understand what isn't working.
Jan 16, 2011 | Panasonic SC-HT650 System
Does not turn on the power green ligh keep flashing no picture and no sound
Hi.
If after the fault the TV went in standby and does not wake up, then the TV has on protect mode after detecting a fault.
When this happens higher voltages are shut down to prevent further damage
In that case follow the troubleshooting here Why my TV does not start up and remains in standby.
The best way to contact an authorized technician is by ringing the phone number listed on the owners manual.
Try first the troubleshooting proposed in link above. If that does not work, ring Panasonic customer service.
Regards.
May 11, 2010 | Panasonic PT-61DLX75 61" HDTV
Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Apr 26, 2009 | Panasonic CT-36D12D 36" TV
Panasonic plasma tv th37pd25
Send me your email if you still need a schematic. I found one online and can send a link or the PDF. airradio2000@peoplepc.com
Mar 21, 2008 | Televison & Video
Panasonic tv ct-27sf37b
Hi!
Please check the troubleshooting chart of the manual.
Hope it will help!
https://manualsbrain.com/en/manuals/1430640/?page=29
Aug 09, 2017 | Panasonic Televison & Video
Computers & Internet Logo
20 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
