Question about iRobot 5800 Scooba Vacuum
Scooba 5800 Power button Red Blinking
Hi, I have used my Scooba 5800 for a few months. Last night, I try to recharge the battery (Power charge plugs into Scooba 5800), but the power button turned red blinking. I did reinsert a few times to ensure the battery sitting on the Scooba properly, still red blinking Kindly advise what's happened? How can I check the battery is still in good condition or die down already? Any way to verify the Scooba charging circuit is ok? by measuring the Voltage readings on the battery connections on Scooba? Any possibility cause red blinking? Bad contact somewhere in the circuit? Thank you very much for any suggestion Edmund
  • 1 more comment
  • Edmund Yuen Aug 06, 2007
    Thanks for your advice, I will try it tonight and see any progress. Do you know how the Scooba detect the battery? by checking the temp. sensor line or something?
    Attached with a photo of battery,
    Many Thanks
  • Edmund Yuen Aug 11, 2007
    Thank you so much
    I will replace the battery before doing the further troubleshooting
    Thanks
  • Anonymous Mar 23, 2014
    red blink fast without battery in
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
You probably have the manual, but here's the link to the Scooba 5800 manual anyway - just in case this would be useful to you: --> http://www.irobot.com/images/homesupport/5800_Scooba_Manual.pdf You could use a voltmeter to check the battery, but only a few months use shouldn't be enough to wear it out. If you don't have a load-tester to verify the battery's load-capacity, then you can check the voltage drop. (Assuming you can get it to contact the Scooba's circuits.) To do this, just check the battery voltage, apply a load by inserting it in the machine and turning it on, then check the battery voltage again. An excessive drop in voltage may indicate the battery needs replacing. However, the red blinking light is Scooba's indicator that it doesn't detect the battery at all. The first thing to do in this case is to clean the electrical contacts on the battery and in the Scooba. Use a damp cloth and a bit of toothpaste to rub the contacts clean on the battery and in the machine. (Toothpaste has mild abrasives in it and will clean the electric contacts without damaging them.) Make sure that both the battery and the Scooba are clean and dry before re-inserting the battery. Also, if the electric contacts in the machine are flexible matal tabs then verify that the tabs are standing up high enough to make good contact with the battery contacts. Hopefully the battery just needs it's contacts cleaned for your unit to work, but test the battery if you are sure that they are clean and seated properly to the contacts in the machine. If the battery appears to be failing, then contact www.irobot.com to cheack and see if they are still covered under your machine's warranty. Hope this helps! :)
Posted on Aug 06, 2007
  • Kevin Omel
    Kevin Omel Aug 11, 2007
    Well, I would assume that the Scooba detects the battery by checking for line voltage on the battery contacts. From a design standpoint, I can't imagine why they would do otherwise.
    However, I did discover a source of more information on this, and other, Scooba issues!
    iRobot has not released any technical or service information on their machines, which is frustrating from a repair standpoint, BUT a group of Roomba and Scooba owners have taken it upun themselves to dissect these machines and discover the technical data that they seek.
    The home site for this group is here: --> http://www.roombareview.com/
    On the matter of your dead battery; a member of that forum has managed to revive an apparently dead battery and his information may be useful to you!
    That message, and the message thread it's a part of, can be found here: --> http://www.roombareview.com/chat/viewtop...
    Is this information useful enough to deserve a better rating now? ;)
SOURCE:
IRobot Scooba 5800 "check tank" light
Why buy something used that is not in perfect operating condition? There may be other problems yet to be discovered.
Dec 31, 2013 | iRobot 5800 Scooba Vacuum
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • Dec 22, 2012 | iRobot 5800 Scooba Vacuum
    Scooba 5800 starts to charge then beeps loudly
    1) test the batteries very well in another device.
    2) test the charges if working properly.
    3) test the power inside from scuba, some electronic components like diode, or capacitor is draining the batteries. repair or rreplace.
    God bless you
    Sep 19, 2012 | iRobot 5800 Scooba Vacuum
    Have Scooba 340 that won't power on after battery fully charged!
    No repair services anywhere, unfortunately. It does sound like you might need a new battery, but the issue could also be the power button. I suggest giving us a call at 1-877-855-8593 so that we can more accurately determine what the problem might be and how we can most efficiently help you to solve it.
    Fembot
    iRobot Tech Support
    Aug 15, 2009 | iRobot 5800 Scooba Vacuum
    My iRobot scooba won't turn on after a full charge
    Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
    Jul 26, 2009 | iRobot 5800 Scooba Vacuum
    Scooba won't turn on
    It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
    May 08, 2009 | iRobot 5800 Scooba Vacuum
    Scooba not working after full recharge
    NiCD and LiOn batteries have this tendency. They work great for a year, then slowly die off. The problem is you. When new, the device MUST be charged for 14hr nonstop, then every 2-3 months run dead, and recharged again 14hrs nonstop. This is done so the CPU of the Roomba (cool toy) KNOWS what DEAD is and what FULL is. It does this by measuring the amount of currrent flowing thru a very precise resistance. If you do hit and miss charge cycles of the roomba or leave it charging too long, it either develops a flase memory of the above two conditions, or gets HOT and the electrolyte paste dries out. Fix is to wear it out, charge 14hrs, wer it out againand repeat 3-4x. Then recharge and use. If that doesn't fix it, the batteries are too dried and need to be replaced.
    Apr 08, 2009 | iRobot 5800 Scooba Vacuum
    Scooba in diagnostic mode
    This is a common issue :)
    his morning, I turned on my Scooba and it started beeping a scale of tones and blinking all its lights in sequence. After an hour or so of resetting, cleaning, disassembling, researching, and scratching my head, I stumbled across the solution on Roomba Review. But, for me at least, it was even easier than all of that. I don't have any of my own pictures for this procedure, but it's pretty straight forward.
    • Remove the battery and power.
    • Remove the two screws holding the bumper shell in place and remove it.
    • Carefully peel up the sticker with the control buttons on it. This sticker is actually the control panel. There is a data cable attached to it just below the "Clean" button. Be careful not to break it!
    • Clean the surface under the sticker with some isopropyl alcohol. (I didn't actually have to do this, but I'm sure it doesn't hurt.)
    • Gently replace the "sticker" (i.e. control panel) and make sure it's completely flat.
    • Check to see if it works again. If not, repeat.
    • Replace the bumper shell and screws....
    thnx.
    Jan 23, 2009 | iRobot 5800 Scooba Vacuum
    Scooba
    Sorry to say, but you have a bad battery. If it's still under warranty, call them and they should replace it. If not, you'll need to buy a new one.
    Apr 05, 2008 | iRobot 5800 Scooba Vacuum
    Scooba 5800 Power button Red Blinking (Continued)
    As for which one has the problem, I would say it has to be the battery. Rechargeable batteries of all types are known to have similar characteristics, one of which is discharging the batteries to maintain good rechargeablility. At least one person has demonstrated this for the Scooba battery in the roombareview.com forums when he brought a "dead" battery back to life. He allowed the battery to slowly and completely discharge using a 12-volt automobile bulb, followed by recharging the battery on the Scooba external charger. This procedure brought his "dead" battery back to a full charge! However, other forum members have reported that many have experienced problems with Scooba battery life, and that as a consequence of this iRobot will replace your battery if you call them and report a short-life battery problem. You can contact iRobot at (800) 727-9077 if you would like to report a battery problem and request a replacement.
    Aug 07, 2007 | iRobot 5800 Scooba Vacuum
    iRobot 5800 Scooba Vacuum Logo
    1,302 people viewed this question
    Top iRobot Vacuums Experts
    Oliver Street
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
