Question about Sharp EL-2197GIII Calculator
User guide INSTALL INK CARTRIDGE
My Epson Stylus NX400 won't recognize any of the ink cartridge after I performed a head cleaning and nozzle check option. There are still ink inside and they are original genuine ink. What should I do?
Did you remove the ink cartridge when you did the head cleaning and nozzle check, if so, did you touch the copper circuit chip on the cartridge? . . The chip is normally what tells the printer how much ink is remaining in the cartridge and if it cannot read this, it may not recognise that the cartridge is genuine and still has ink remaining inside. . . .You can try cleaning the chip with a soft dry cloth otherwise you may have to install a replacement cartridge. . . See http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469 for the User Guide showing how to replace ink cartridges for this printer.
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
How do i change ink
hello
first of all identify and familiarise yourself with the ink cartridges -- BLACK INK #36XL, COLOR 37XL
if you do not have the users guide, download or save this (PDF format)
go to this link to obtain the users guide http://www.lexmark.com/publications/pdfs/2007/5600-6600/v7677571_en.pdf
in this guide it will illustrate and instruct you on various aspects of this A.I.O printer
to install cartridge, go to page 111, see link here http://www.lexmark.com/publications/pdfs/2007/5600-6600/v7677571_en.pdf
with the printer ON, lift the p cover to expose the inside where cartridges are .. the carriage will automatically go to the center for you to remove the cartridges. There is a tab you will have to lift to get to the cartridge seat. follow instructions on that page, 111 of users guide.
please send me 4 thumbs up
Jan 29, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Install ink cartridges for an Epson 315 workforce
If you do not want to go through the guide, here is a quick instruction on how to insert the ink cartridge.
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. If an ink cartridge is low or expended, you see a message on the WorkForce 310 Series LCD display screen indicating which color to replace. Press OK. If you're replacing a cartridge before you see a message on the WorkForce 310 Series LCD display screen, press the ink.9.7.1.jpg Copy button, press ink.9.7.2.jpg Menu, press ink.9.7.3.jpg or ink.9.7.4.jpg to select Maintenance, and press OK. Then select Ink Cartridge Replacement and press OK. 1. Open the scanner, then open the cartridge cover. ink.9.7.5.jpg 2. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.9.7.6.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 3. Before you open the new cartridge package, shake it four or five times. Then remove it from the package. ink.9.7.7.jpg Caution:
Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 4. Remove the yellow tape from the bottom of the ink cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 5. Insert the new ink cartridge into the holder and push it down until it clicks into place. 6. Once you replace all the cartridges that need replacing, close the cartridge cover and push it down until it clicks into place. ink.9.7.8.jpg 7. Close the scanner. 8. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Go through your user manual for further guide on how to install ink.
Jan 16, 2011 | Epson Office Equipment & Supplies
How do i change ink cartridges
Hello i hope u 'll be fine.... thanks for using fixya.
Probably
Lexmark X4650 InkJet Printer User Guide will be able to guide you. If you have already installed the Lexmark software on your system you can view the User Guide by going to the Start menu >> Programs >> Lexmark X4600 Series >> User Guide. Scroll to page 94 for instructions on how to install the ink cartridge. If not, you can download it for free from here
User Guide is in pdf format if you have no Adobe Reader software which support .pdf files then Download it from here Adobe Reader
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source.With the cover open,hold the solid white strip and gently slide the carrier to the middle of the printer.Remove the used cartridges. Load the new cartridges.Close the cover.Plug the printer back to power source.
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Dec 30, 2010 | Lexmark X4650 InkJet Printer
Installing ink cartridge
Perhaps the Lexmark X4600 User's Guide will be able to guide you. If you have already installed the Lexmark software on your computer (Windows), you can view the User's Guide by going to the Start menu ? Programs ? Lexmark X4600 Series ? User's Guide. Scroll to page 94 for instructions on how to install the ink cartridge. If not, you can download it for free from the Lexmark website at Lexmark X4600 User's Guide.
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to power source.
Hope this helps. Thanks.
Nov 19, 2010 | Lexmark X4650 InkJet Printer
How do I install new color cartridge
You can refer to the Lexmark X2600 user's guide. If you're using Windows and you have already installed the Lexmark software on your computer, you can access the user guide by going to the Start menu -> All Programs/Programs -> Lexmark 2600 Series -> User's Guide. Go to page 44 for the steps on how to install the cartridges. If you can't access the user's guide, you can download it from the Lexmark website for free. Click on this link: Lexmark 2600 Series User's Guide.
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the center of the printer. Load the color cartridge into the right carrier. Close the cover. Plug the printer back to power source.
Thanks.
Nov 07, 2010 | Lexmark X2600 InkJet Printer
How to install a new ink cartridge in Lexmark 2350 printer/scanner
Perhaps the Lexmark X2350 User's Guide will be able to help you. Just click on this link to download: http://bit.ly/bNOTdZ. Scroll to Replacing the print cartridge, Page 52, for the instructions on how to install your new ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Sep 15, 2010 | Lexmark X2350 All-In-One InkJet Printer
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
Sharp EL-2197GIII Calculator Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
