Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT-47WX49E will not power on
I have a Panasonic PT-47WX49E rear projection TV. Since this morning, I cannot get it to power on. If I turn the power on, I hear some static noise (like static electricity rippling through the system), and then it just turns off. I then try to power it on again, and nothing happens. If I unplug the power cord from the wall outlet and plug it back in I can replicate the turning on followed by an almost immediate turning off again. There is a slight electrical burning smell. Any help would be appreciated. Thanks
  • 58 Answers
Thats a power supply module going bad. Dont use it until a person with knowledge on TV see that. Or if you feel you can DIY open the back panel to see if there is a toasted or foreign object near the power supply area. Its located when you follow the main plug going into the back panel of your TV. Look for a dying Fuse too. And watch out for Capacitor that has still current, you may electicuted with that component. That parts its only for qualified servicemen area only.
Posted on Aug 06, 2007
SOURCE:
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47wx49E
does the led indicator blink? If so how many times does it blink?
Sep 04, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Blue ghosting on Panasonic PT-47WX49E
your convergence IVs need to be replaced. Its an easy repair if you can solder. you can get the two ICs you need at the following link. they also provide free installation instructions and free on line tech support while youre doing the repair. You need two ICs they are numbers STK392-110. Let me know if I can be of further assistance. I am one of servicemanuals support techs and board rebuilder.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49E Doesn't work
This is for sure a safety shutdown circuit that is shutting down this TV set. It is a hard call to pinpoint a problem such as this without first doing some troubleshooting on the TV set. You could have a short in the sweep power supply, the horizontal output transistor could be bad, therefore then the flyback is probably bad, or the vertical IC could be bad, there could be a regulator problem in the main power supply that could be bad, and also the convergence IC's can cause this problem. Almost any circuit inside this TV set can be detected and staop the set from starting up. Good Luck
Jun 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
219 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
