I have music on my LG shine but when i put my memory card in it will not let me get any more songs onto my phone even my memory card so when i put it in and someone tries to send me a song it says memory full ! what can i do ???
Same thing here. I put the card into the phone and then hooked phone up to the computer and it recognized it. If you're downloading songs for use as a walkman, the default setting for the card will work. I got the card to make my own ringtones and had to set it to 'mass storage' in order to drag my tones in. I found the program for downloading songs directly to the phone too confusing for me.
go to att music and go to music player hit all songs. it will update the library and show the songs from your card, you can play them from here but i don't believe you can use them as ring tones from here.
i have the shine and you have to get a usb connector cable which can be purchased virtually anywhere. when you connect using the isb you connect as music sync and in which part the folder for your phone will show up on your computer. yet before you connect with the cable if you want any of your pictures on your computer you have to go to pictures then options then copy to memory card then in the folder you want. after doing this you may connect and drag the picture(s) off of the folder and the picture will stay on your phone and computer until you delete it. you can also put songs on your phone using the memory card yet it isnot compatible with itunes any MP3 song can put on there. Just check the owners manual on the shine it explains the music and sd card further. I hope this helped and the lg shine is a great to use I have had mine for years, merry christmas.
If you want to put music files from your laptop onto your LG Shine, you can either use a LG USB cable or a Micro SD Card.The Micro SD card will probably need an additional adapter to have it big enough for your Laptop or PC slot. Once the music files are on the Micro SD card, insert the card into your LG Shine and go to My Stuff". Then, select "Audio and ringtones" and select the file on your memory card. Press the "Options" button and select the copy function and paste it into your phone.
To find your music on the SD, go to my stuff, sounds, external memory, mp3 and you should see your music. Playing it, however is another matter. You can play only one song. Then you have to manually play the next one. Not what I'd call an MP3 player.
You gotta go to your lg shine, set the connection as MUSIC SYNC, and then open up windows media player
it should say LG PHONE or something like that, and drag n drop your music files.
I just got a new LG shine CU720 to format the card you go to settings, reset settings, master clear, memory card, my security code was 0000. Hope this helps someone else looking.
I have tried putting a different memory card in but it still will not work !
